Headbarcode
- Mike
- Aug 16, 2018
- LI, New York
- 2019 JLUR Stingray 2.0 turbo
- Vehicle Showcase
- 1
I have to agree to disagree, as I wasn't passing on thoughts and feelings.I respectfully disagree that tire circumference is a primary concern, but appreciate the thoughtfulness of your explanation.
Can any of these after market devices adjust the RPM shift targets on the power band? Can they alter the pressure thresholds in the Torque Convertor? Can you use them to tailor the algorithm for the specific curb weight of your modified vehicle, and the implied inertia of the vehicle?
The auto transmission has plenty of information to work well without prioritizing tire size. Changing tire size doesn't change the power band of the engine. The torque convertor doesn't need to know what tire size you have to do its job well. There doesn't seem to be any opportunity to tell the Jeep what the gross vehicle weight is, so the inertia during acceleration, deceleration, and cruising, on flat or angled grades, seems to be more or less generalized rather than specific.
If you were shifting a manual with newly introduced changes such as bigger tires or different gears, you would still shift to make best use of the engine's power band , just like the automatic transmission does. You would know exactly where to shift because... you know... you know when to shift without thinking about tire size, or gear ratio, or any of that.
If you wanted to you could discern that something about your Jeep had changed, e.g. the land speed where the changes occur are now at different rates, but that would not have to equate to a problem unless you made it one in your imagination.
It's nice to have an accurate speedometer, but IMO a modified Jeep can be enjoyed with out hacking the software.
All the best!
Curb weight varies, and translates as engine load. The focus in this thread are the set points. Also, we're not talking about engine and transmission tuning, but simply a body control module programmer. This is a well known reality. No place for imagination in a technical conversation.
A simple analogy would be a programmable coffee machine. As sophisticated as it could be, it still requires an accurate clock because it doesn't know that the sun's coming up on its own.
Algorithms require both variable and set data points. Each one has equal importance to the collective, when looking for the best results.
