2021 JLUR Sky one touch leaking
Lonewolf62
Edward
Gallatin, TN 37066
2022 JL Rubicon V-6
Wife’s 2021 JLUR has developed a leak somewhere near the drivers side back passenger area above the edge of the door jam and side window. Noticed a bad leak yesterday after a normal rain event, no downpours. Window has never been off, checked all the bolts I could reach and they are all tight? Any one else have this issue and or ideas as to what to try? Still under warranty till May of 2024.
Opus
Midwest US
www.jlwranglerforums.com
If it was me, I would take advantage of that warranty while I had it. Take it to the dealer so the problem is on their radar before time expires. Then, if somebody on the forum with a SOT has a simple solution, great... but if not it's still the dealer's (known) problem to fix.
Lonewolf62
Lonewolf62
Edward
Gallatin, TN 37066
2022 JL Rubicon V-6
Thank you, I will see what the dealer says. Just can’t be without the vehicle for extended period of time while they tinker with it.
mjg4xe
Michael
CT
2022 Jeep Wrangler 4xe Rubicon
I would comb through all the weather stripping in the area, both on the SOT and door/windows. The instances I have seen on here usually are a problem with weather stripping coming loose somewhere (and would be replaced under warranty). The adhesive they use on them can be even sloppy from the factory, so would check the leaky side vs the non-leaky side to see if there is an area that needs to be fixed.
