2020 rubicon side window panel latch noise
rad2022
royal oak, mi
2020 Jeep Wrangler Unlimited Rubicon
First time post… I apologize if this is the wrong place for this. I have a 2020 unlimited rubicon with the sky touch roof. About a year ago I started hearing this incredibly annoying squeak anytime I would hit any bump. I initially thought it was my sub. I took it in for service and was told some inner panel needs replacing and that the latches that hold the window panel had a recall and were replaced. PROBLEM FIXED! Fast forward to a few weeks ago when the noise started up again. It was driving me crazy. To a point where I was going to sell my Jeep. I got in my back set and just started knocking on things until I figured out that it was the back window latch that was squeaking. Has anyone had this same issue and how did you fix it?
Terpsmandan
Penn Yan
Maybe a little spray silicone lube on the contact points. That latch was adapted from the freedom panels and might not be as happy in a vertical setting.
