mxracer1983
- Jake
- May 1, 2022
- Munday, WV
- 2022 Jeep Wrangler Unlimited Sport S
So I have a 2022 JLU Sport S. I found a new in box 2.5" Skyjacker Blackmax lift for $250. It's for a Rubicon model. My mechanic said that the sway bar links are little longer but otherwise it would work. I went ahead and bought Skyjacker front and rear adjustable track bars and adjustable front LCAs. After the install, I noticed that it does stand a little taller than I expected from a 2.5" lift...which I'm okay with. My mechanic said he has the caster adjusted to 5⁰. I have a slight shimmy between 40-50mph. He told me to bring it back in and he'd check the tire balance again. I have seen some of you guys saying that JLs are finicky about caster and some have went as much as 6⁰. Would the shimmy have anything to do with the caster? I adjusted the psi down in my tires down to 30lbs and that helped the steering flightiness a bit but still have the shimmy.
Also, I called Skyjacker and told them the situation. The tech was VERY adamant that a rubi lift wouldn't work on a sport s because it would throw the geometry off. I told him that I bought adjustable components to correct the geometry but he still insisted that it wouldn't work. I realize that the springs may be slightly taller along with the sway bar links but shouldn't everything "fit" a Sport S? He did tell me to adjust the LCAs to 24.25" as a starting point for caster adjustment. Any tips, advice, and pointers would be appreciated! Thanks guys!
