2.0 engine Turned on when warm with weird sound
Khoder
Tony
Mopar321@
Wrangler rubicon 2023
Dear All,
I'm having a weird sound coming out from my 2.0 turbo engine.
The sound is occurring when the engine is warm and after a drive not on cold start.
When turned on, low RPM and major ticking sound comes up.
The dealer could not find the problem and fix it after more than 7 visits.
Is this common, please advise.
Khoder
Khoder
Tony
Mopar321@
re-attaching the video
diesel_dave
Utah
2023 Rubicon 4xe
I was getting my "don't worry about it, the 2.0L is a noisy engine" comment ready, then I watched the video... Yeahhh, you're gonna wanna take that bad boy to a *competent* shop before it blows on the freeway.
If the shop you have been going to can't find the source of the ticking, then they aren't trying very hard. I'd say it is likely some kind of valve train damage and I wouldn't want to keep driving it like that.
Khoder
Khoder
Tony
Mopar321@
It goes away after 10 sec after turning on the Engine and not on cold start it occurs only when the car is warm.
I took it to the local dealer and they dnt knw what they are doing unless when the Check Engine light is on, in my case it is not
four low
central New York
2018 JL
What oil and filter are you using,? Hopefully the recommended oil and filter for the 2.0 T you see in the manual. Hard to determine without this factor being taken into account.
diesel_dave
Utah
2023 Rubicon 4xe
Oh the fact that it goes away after 10 seconds changes things a bit. When was the last time you changed the oil?
Khoder
Khoder
Tony
Mopar321@
It was like that since I purchased it (0 miles on it)
I have changed the oil as I expected the same but no luck.
I’m using mopar genuine oil that comes in the manual
Khoder
Khoder
Tony
Mopar321@
Did you Guys had the chance to know what is the problem or if it is normal ?
