i havent seen anyHave there been any 24+ JL’s with an oil cooler leak? That’s when they went to the new gasket design
The Dorman unit is hit or miss. If you follow Autoedits on YouTube, he put one in his JK and it ate shit immediately, but he replaced it with another one and it worked just fine.I watched that yesterday. Good video.
is the dorman oil cooler the current preferred product? I remember people were recommending the updated oem oil cooler.
Sitting at 30+K now with zero issuesHave there been any 24+ JL’s with an oil cooler leak? That’s when they went to the new gasket design
the new design oil cooler?2022 started the new design and my 22 went bad at 18,000 miles.
well that fcking sucks lolThe Dorman unit is hit or miss. If you follow Autoedits on YouTube, he put one in his JK and it ate shit immediately, but he replaced it with another one and it worked just fine.
Yes, he described a different method: moving the AUX (ESS) battery positive terminal connector to the main battery positive post.Does anybody know why Jerry in the video (26:54) did not talk about the F42 fuse removal when he spoke about the auxiliary battery delete process he suggested? Is what he discussed just a different way to do it? Is the F42 fuse removal optional in an auxiliary delete process?
If you're talking about the oil cooler I'm pretty sure they changed the gasket in 24 to a figure 8 design2022 started the new design and my 22 went bad at 18,000 miles.
3.6Does the oil cooler issue only apply to the 3.6 or does it impact the 2.0T also?
