WhereRU_A-A-Ron
Aaron
Arkansas
2021 JLU Willys, 2023 Ford Expedition Stealth Edition, 1968 Mustang Coupe 289
Business Director
Today’s project was installing the Air Lift 1000 rear helper bags on my ‘21 JLU Willys. Having never installed anything like this before, I have to say this was shockingly much easier than I thought it would be.
With the suspension at full droop, it’s incredibly easy to install the air line and the bags. There’s a ton of room to work around. I’d seen everywhere that the hardest part of this install was shoving the bags in between the spring. I would agree but it was much easier than I thought it would be.
Jeep Wrangler JL Air Lift 1000 Install - Quick and Easy IMG_6471
Jeep Wrangler JL Air Lift 1000 Install - Quick and Easy IMG_6472
Next you have to run the air lines along the frame to the rear and use a few zip ties along the way. The instructions show you exactly where to use zip ties for best results. I chose to keep both lines separate for more a more customizable solution and less connections that could become points of failure. You can combine both lines together if you like for simplicity.
I ran my lines all the way to the rear of the frame and threaded the line down through it. Ironically, there are four hexagonal openings in the bottom of the frame that the supplied hardware fits through exactly making for an incredibly low profile install.
Jeep Wrangler JL Air Lift 1000 Install - Quick and Easy IMG_6476
Following the instructions, you can install your valve stems right here. I had to put the lock washer in through the larger hole to the top of the picture but it was very simple the get my finger in there and feed it right over the hole.
Jeep Wrangler JL Air Lift 1000 Install - Quick and Easy IMG_6473
This makes for an insanely clean install. You cannot see the valve stems when standing behind the Jeep, which I like and I think will greatly discourage someone coming along and messing with them. I also just like a more factory installed look but that’s just me. If you have the Tow Package, one of these hexagonal openings is being used to secure the trailer plug bracket but there are three others to work with.
Installing the heat shield was definitely the quirkiest part of this install. I have the 3.6 so the exhaust runs down the driver side.
Jeep Wrangler JL Air Lift 1000 Install - Quick and Easy IMG_6483
The install is frankly quite easy and the heat shield is very pliable and can easily be shaped to the contour of the exhaust. I will say, I felt like the instructions were lacking here and there’s really nothing said about where and how to place it. I mean it’s kind of obvious what it’s trying to accomplish but I think it would’ve been nice to get some reassurance from the manufacturer that it’s in the right place.
Don’t forget to spray connections with soapy water to check for leaks before you drop the rear back down on the ground. You’re done!
I haven’t had a chance to test these out yet but there have been several occasions when I could’ve greatly benefited from having these. No more getting flashed at when I’m taking the family camping or hanging bikes off the back. I’ll update the thread once I get a chance to truly test them out.
Hopefully this helps someone else out there looking for an install write up. If anyone wants more pictures or specifics I’m happy to help. Cheers!
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
I installed Airlift bags on my JL a couple of years ago then installed their compressor, gauge and switch setup last fall. Works great, when loaded heavy or towing a trailer a quick press of the button and the Jeeps level again. When unloaded, just press the bleed-off valve and back to normal.
cseaman
NOVA
2024 392, 2023 SQ5
I just had 1000s installed along with Air Lift's Wireless One compressor mounted to the frame. It is absolutely awesome for those who have weight on/off consistently and tow regularly.
WhereRU_A-A-Ron
WhereRU_A-A-Ron
Aaron
Arkansas
Business Director
We’re looking at purchasing a camping trailer and even though it’ll be well under the capability of the Jeep, I remember towing very lightly before and the ride was much worse. I don’t want that experience again. Even throwing all of our camping gear in the back and both kids made the ride noticeably worse. No more.
cseaman
NOVA
2024 392, 2023 SQ5
Yeah, we don't have kids but we are prepping for a ~40 day trip from AR to ID/OR/WA and back to KC via CA/NV/UT/CO. Trailer will go on and off the JL almost every day of the trip, so I went with the Wireless One. I'd take a look if manually adjusting every day isn't something you're into.
Here's our trailer prior to the 1000s on the JL.
Jeep Wrangler JL Air Lift 1000 Install - Quick and Easy BAC8A2BB-BB55-44F3-8A9F-CEEDDA316A26
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
I've got a set of the 1000 HDs on my Ram, and had the same positive experience.
Pretty sure I'm gonna order a "custom" set for the Jeep for when we tow the trailer. A little concerned on how they'll hold up to the flex.
cseaman
NOVA
2024 392, 2023 SQ5
I'm not saying this as a matter of fact, but I did a lot of research here and in the FB owner groups on these bags prior to purchasing because I was going back and forth on doing the AEV HD lift instead of the bags..if flex is a priority, I think you're probably asking to have a bad time with bags.
I did a hellwig rear sway at the same time as the bags because my priority is stability with my trailer and the jeep won't see anything crazier than fire service roads without the trailer. It seems that most people who try and do genuine 'wheeling' end up having issues with the bags leaking or failing altogether.
GATORB8
CLT NC
Yeah, it be nice to have a little help, more for rake/vanity than anything. The MC 3.5s handle it fine (I've got about 15k towing the trailer).
Will
Will
Georgia
'18 JLUR
I installed the kit in 2021 and have been very happy with it. The functionality that you get for the money can’t be beat.
I had concerns about wheeling with it, and have been pleasantly suprised that the bags both still hold. I did have to replace one section of air line that was pinched on a wheeling trip. I also have limited suspension travel over stock with a 1.5” lift and a 2” bump stop extension so that may be a factor in longevity when wheeling. The Jeep is more family rig than anything else but we have been on challenging trails since installing this: Windrock, Choccolocco and 3 or 4 other trips.
It was great when we had the trailer, but even since we got rid of the trailer, I’ll add/remove air at my leisure if I don’t like the way the jeep is sitting. It also helps with squat when loaded down for roadtrips/cargo carrier/bike rack. It’s such a small volume of air I just use a bike pump and it’s easy access at the rear bumper.
After a front lunchbox locker in a TJ, it’s the best bang for the buck I have ever spent on a vehicle mod.
Jeep Wrangler JL Air Lift 1000 Install - Quick and Easy IMG_3756
Jeep Wrangler JL Air Lift 1000 Install - Quick and Easy IMG_3755
Jeep Wrangler JL Air Lift 1000 Install - Quick and Easy IMG_3754
Jeep Wrangler JL Air Lift 1000 Install - Quick and Easy IMG_3753
WhereRU_A-A-Ron
WhereRU_A-A-Ron
Aaron
Arkansas
Business Director
I appreciate everyone sharing their experience with towing and/or wheeling. These were all questions or concerns that I had so I’m getting answers proactively answered. :rock:
Will
Will
Georgia
'18 JLUR
When we wheeled with you at Gulches, we had this kit installed. You have more flex with the Metal Cloak kit, however, and spend more time wheeling than we do.
RubiBlueJLU
Missouri
2021 JLUR Diesel
Structural Technician
Installed a set on our 2021 JLURD a few months ago, in preparation for purchasing a travel trailer. Went ahead and got a weight distribution hitch (used) to help, too.
Installation was a breeze, as stated above.
Only caveat is to install both Schrader valves and run 1 air line to each. This will help mitigate the body roll on turns, while towing. With both lines to 1 valve, air can pass back and forth.
I towed or "new" Mallard M185 (about 4100 lbs) without the WDH and it handled great. Almost no sag at 35PSI in the bags but still a little porpoising. WDH took care of that.
Towed it 1300 miles, no issues. Except for mileage hit, couldn't tell it was there.
I do drop them down to "no air" when not towing.
Jeep Wrangler JL Air Lift 1000 Install - Quick and Easy trip2
WhereRU_A-A-Ron
WhereRU_A-A-Ron
Aaron
Arkansas
Business Director
Hello fellow Arkansan :captain:
Love the ROG trailer. Have y'all ever made it up to the Rendezvous in the Ozarks event? We're hoping to have our trailer before the event this year.
WhereRU_A-A-Ron
WhereRU_A-A-Ron
Aaron
Arkansas
Business Director
Added a picture of where and how I installed the heat shield. I took the picture within less than a minute of getting back home today with the exhaust and everything still nice and hot. The bags and the lines felt more or less cool to the touch so I feel confident now nothing is going to melt or get too hot.
LKG
Larry
Boise, ID
23 JLUR (soon), Gen 2 Cummins, 22 Sport Alt. R.I.P
Way back in the late 1,900's I used a set in the front coils and bastard packed the rear leaf springs to lift my 87 XJ. I beat the hell out of the XJ, they never failed. I did, in fact fly for short distances on several occasions. Best budget lift ever for a poor 20 something punk kid.
I had no idea they even still made them, I just might throw a set in the JL for those overloaded trips.
