LarryB
- Larry
- Feb 18, 2021
- Calgary, Alberta
- 2018 JL Sport 2 dr
I bought my 2018 (it was about 2.5 years old) with only 7000 miles on it. It had sat for a long time. The dealer replaced the aux battery, as it was fried, but did not want to replace a borderline main battery. I didn’t bother to press and just bought an Odyssey, which is what I like to have in my vehicles anyway. Anyone buying a very low-used JL should consider their batteries to be suspect and likely needing a replacement.Didn't need the rest after this line. Lead acid batteries slowly die when sitting in an idle modern vehicle that's constantly draining a little bit of power even when off. The Jeep's aux battery config only exacerbates the problem.
If you know your Jeep is going to sit idle for a while, put a trickle charger on it so it doesn't shorten your battery life.
