yellow ESS light with exclamation mark on dash
sourdough
left coast
JL-sold
So I connected a 4 amp battery tender until float mode came on and tested the aux and its good at 12.58 volts. Test drove a couple miles but the light remains on and stop/start is not working. Whats left to check?
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
You have to clear the error. I use a code scanner, but I think disconnecting both batteries also works.
Htfan
Orange County, CA
2018 JLU Sport S - 3.6L
Also after you clear the error, 12.58v still seems low for your Aux AGM battery after a charge. Mine sits around 13v with no load. I would guess your Aux battery is on the way out.
sourdough
left coast
JL-sold
That would not be surprising. My battery tester did say it was good. So I'll try clearing the warning light for now.
