Windshield Washer not working some times
Suffolklou
Suffolklou
Lou
Richland Wa
2020 JLUR
Good to know, I will try the rear glass next time mine doe not work.
jeeperdxb
Dubai
2024 Rubicon JLU Earl | 2015 Sport JKU Tank Green
Just to update. I took my Jeep to the dealership and they fixed this issue. As per them, they said that my hose has kink and they replaced the hose. Now, so far so good, no more issues.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
You are definitely not cavitating the pump, not even close.
Ghostpilot
Michigan
2024 Jeep Wrangler Rubicon
I know it’s a very old thread, but is there anyone figured it out? I have a brand new 2024 JLU Rubicon, If I don’t the use the washer for few days, it stops working. I can hear the hum but no water coming out. Some times, I have to turn off the engine and start again then it starts working but sometimes the only way it will work is if I open the hood. If I use it everyday, it seems to work fine.
Check your washer hose routing under the hood. I haven’t had a problem yet, but I noticed the hose gets pinched between a hard foam piece that appears to be a wind or water block on top of the firewall on the drivers side. I think the hose is just too long or slack needs to be pulled through the clips to shorten it in the area where it gets pinched.
