Suffolklou
- Lou
- Dec 3, 2019
- Richland Wa
- 2020 JLUR
Good to know, I will try the rear glass next time mine doe not work.
Check your washer hose routing under the hood. I haven’t had a problem yet, but I noticed the hose gets pinched between a hard foam piece that appears to be a wind or water block on top of the firewall on the drivers side. I think the hose is just too long or slack needs to be pulled through the clips to shorten it in the area where it gets pinched.I know it’s a very old thread, but is there anyone figured it out? I have a brand new 2024 JLU Rubicon, If I don’t the use the washer for few days, it stops working. I can hear the hum but no water coming out. Some times, I have to turn off the engine and start again then it starts working but sometimes the only way it will work is if I open the hood. If I use it everyday, it seems to work fine.
