Willys on 35s...
ItsNo4RE
NJ
21 JLU Willys/17 Ram 1500
Ok guys, so as we know, the Willys sits at stock Rubicon height. If I get the hi rise fenders then I should be able to fit 35s. Right? If that's the case, do I need the rears as well or can the stock rear flares accommodate 35s?
Rlhdude
Rick
CT
Wrangler JL Limited Willys
Willys needs Rubi springs and Rubi sized wheels to sit at Rubi stock height.
Dr. RGB
Ryan
Leesport, PA
2025 JL Willys 2-Door
Professor and Shrink
Willys ride on stock Sport suspension. You will need to get the Rubicon springs. I ordered mine through Mopar and purchased the longer control arms as well. Later, I put in 3/4 inch leveling pucks in the front. All I need are the Rubicon fenders and will be set for 35" tires. Be warned that the Sport/Willys axles are narrower than the Rubicon D44's, so you may need new wheels with greater backspacing. There are tons of threads about this.
BlackGenesis
Andrey
Muskegon Michigan.
18 Sahara unlimited
To run 35s without rubbing, you can go about it few ways.
Rubicon springs and Rubicon flares.
Rubicon springs and 3/4" spacers (daystar spaces)...leave current flares.
Both options might need more offset wheels or wheel spacers.
