Where can I get these interior map lights?!
Ormond Beach, Florida
Retired at 55 ..
Completely agree!
It's a great product idea, but the fact it uses batteries makes it "lower quality" in my mind. I didn't purchase for the same reason.
If it was less expensive, I would consider going through the hassle of wiring a step-down to 4.5v (3 x N battery 1.5v)
I wouldn't install that crapola offering if you gave it to me for free.
jromanmd
Jon
Annapolis
2023 Jeep Wrangler Rubicon
Forget the lights. What is that rear view display? that looks badass!!
LooselyHeldPlans
Brandon
SW Colorado
2020 3.6 JLUR
Several
I installed that map light in my Jeep, and report on it here.
Any chance you could take a photo of the battery “bay”? I’m trying to see if they’re ran series or parallel so I can buy the right components for a hardware install. If I do, I’ll make a write up soothers can benefit.
Heimkehr
Pennsylvania
2021 JLU 2.0T
As requested.
Note that N cells are used.
Jeep Wrangler JL Where can I get these interior map lights?! 20240109_142440
Terrymo
Terry
2023 JLURXR 3.6 ET
Probably a long shot, but don’t most DC led lights function in a voltage range rather than at a specific voltage? I am curious if you just hard wired them at 12 volts if they would work? Maybe not worth risking it since the assembly is not cheap.
LooselyHeldPlans
Brandon
SW Colorado
2020 3.6 JLUR
Several
As requested.
Thanks! Series as I suspected.
Most will run on a range, but it’s limited. My Jeep likes to sit at 13-14v. The pic above shows series, so the batteries are doing around 4.5v. 13v would likely fry this as its almost 3x.
You might be able to get away with 5v with is super common to obtain as it’s the standard old USB voltage. I’m goin to try 5v on one that I pick up.
