When I needed it most…
AskBin
22' Willys EcoDiesel
id start with reading the pids. not sure if jscan allows you to monitor wheel speed and steering wheel position, but if it does id start there.
you said you dialed in the steering wheel to be straight, was the steering angle sensor recalibrated to zero? ive seen that cause issues in other cars before, and the hunter machine i used to use would always remind us to recalibrate that after an allignment.
possibility that the combo of that and the heavy winds could have knocked your car around that the gyroscope in the RCM just wasent a fan.
but i also had the same code and my trans completly locked me out when my POS aux battery shit the bed, and killed my main battery at the same time...
Heimkehr
Pennsylvania
2021 JLU 2.0T
Imagine this, you are driving your wife to her hospital night shift, because essential workers must come in to work during the storm and you of course chose to take your extremely capable rig to handle the task.
On the way back from the hospital, when the ice rain and 40mph wind gusts are at their fiercest, your car decides to give you a check engine light. It then tells you “Service Electronic Stability Control”, and it refuses to shift out of gear and stays stuck in D5, even when coming to a halt.
Any thoughts/ideas what could be causing this?
Yes.
Click.
(Post #147, if it ever gets lost in the shuffle.)
LAM
Larry
Bay Area California
2022 Sahara 4XE
Has happened to me twice, and after installing a lift. In both cases after using 4LO, and playing in 4HI with ESC manually turned off. The warning light stayed on after getting back on the highway. In both cases the warning did not come on the next day. Pretty much isolated incidents. Somewhere I think I read the light might come on if your steering fluid is low, and the first time I added some. Steering wheel angle is an interesting concept. Mine is around 10 degrees counter clockwise; I sort of like it that way.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
You should consider turning it lock to lock on dirt or gravel. Then, of course, straighten the wheel.
  • Like
Reactions: LAM
