Wheel backspace ?
DeVoTee
Nebraska
12 JKU Rubicon, 17 JKU Sport on Roids, 18 JLU Rubicon, 19 JL Rubicon ordered, RAM, Range Rover
Does anyone know the most amount of backspace (without rubbing on the frame) on Rubicon axles?
MacBigButt
Martin
BC, Canada
Nissan Leaf, 2018 JL Unlimited Sahara
Jeez, those look HUGE for 34s! Is there some flexing going on in the rear tire in that side shot that makes them look like they fill up the wheel well more, especially with the lift? The front looks more like I'd expect. I have a JLUS with 1.5" leveler on the front and am debating between 285/70/17 and 285/75/17. I like the fuller wheel well look, but don't want to rub. I don't plan on rock-crawling, but would like to take it on trails.
Sorry for the late reply, I've been offline for a few days.
Yes, in that particular picture the front was up on a rock so the rear is compressed a bit. The angle of the picture looks worse than it is.
The Nitto 34" work without a lift on the front but you can stuff the rears at max compression, not enough to do damage on mine.
TroyBoy
Troy
Vancouver Island, Canada
-12 offset sticks out further than the 1 offset by exactly 13mm
edzel14k
Champ
Raleigh north carolina
Jeep Wrangler Sahara JL 2018
I have pro comp vertigo 18x9 offset 0 back space 5, with tire 275/70r18. But i want to know if there is negative impact or disadvantage on this, I have the sahara model with a 2 inch lift
Or do i need a wheel spacer for this?
blnewt
New Mexico
Just ask @cosine he knows!
You're changing the positive scrub radius by moving the centerline of the wheel outward (stock offset +45, your offset zero) but you're not going super aggressive, steering won't be as affected as if you were running -18 offset for example. With the 275 width tires on that offset your Jeep should still handle close to stock assuming you're able to keep the rest of your steering geometry close to stock.
