What Audio upgrades for $500?
TankCustomsAlex
Alex
Houston, TX
2019 Jeep Wrangler Rubicon 2dr Mojito
I have the 8.4 Uconnect in my 2019 Rubicon. I think the audio system is ok, but wish it was better. However, I'd rather spend the money on other mods. But let's say I spent around $500-$600....are there any worthy upgrades at that price point...speakers? Etc. Not looking to spend too much, not expecting a whole lot either.
Jeffmiller32
Scottsdale, AZ
2019 JLU 2016 Mustang GT
Speakers without an amp won’t do too much to improve the sound. Actually might make it sound worse. You can add a powered sub for pretty cheap or a small amp and 10” sub and box for around $500-600.
RubenZ
Ruben
Deep South Texas
cyberrube.com
2018 Silverado 2500HD Duramax, 18’ Toyota 4Runner
Honestly, you neeeeeeeeed a dsp amp for aftermarket audio to be worth a damn.and unfortunately they cost a nut.
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
Mail311
Stroudsburg pa
2021 Unlimited Rubicon Xtreme Recon
Replacing all of the 3.5in speakers is an economical way to get a little bit better sound. I believe with the 8.4 in the rubicon, you already have the alpine set up. I installed kicker speakers using splice connectors to the stock speaker wires. Once I figured out what the hell I was doing, it took very little time and sounds a lot better.
TankCustomsAlex
TankCustomsAlex
Alex
Houston, TX
Yes, the 8.4 is the Alpine setup. Is that what you have? What Kicker Speakers did u go with? I'm just looking to improve the sound quality a bit. Don't think the stock system sounds that great. Maybe, I need to invest more $.
TankCustomsAlex
TankCustomsAlex
Alex
Houston, TX
If $500 is your budget, just get some wireless Bose headphones and turn your Jeep stereo off
lol I got some more important mods that I need to get for my current setup. But I figured if there were some decent speakers that would make a slight difference then i would swing for it. If not, Ill just wait and put more money into it. Was hoping there was a $500-$700 upgrade worth doing if expectations werent that high. Im just not too impressed with the stock 8.4 alpline sound quality.
RubenZ
Ruben
Deep South Texas
cyberrube.com
Alex,
YOu're gonna have to save up if you want an improvement over the Alpine setup. If you had the base system then just replacing a few speakers helps A LOT! In your case you have to do a complete make over to get better than what you have with the upgraded audio. The problem here is the Amps are just so dang expensive.
TankCustomsAlex
TankCustomsAlex
Alex
Houston, TX
TankCustomsAlex
TankCustomsAlex
Alex
Houston, TX
Alex,
I was afraid that would be the answer lol Ill put more money into it eventually, but its not on high priority right now. Just like to plan ahead. The stock system is bad at all, but its not that great either.
RUSTYS
Rusty
PA
JLUR
Guitar slinger
His Jeep came with an amp and a alpine sub. It's not the standard trash stereo.
Rploaded
Houston
2019 JLUR
You could sit in my Jeep and use my stereo. :CWL:
Alex, best thing to do is just save until you can get exactly what you want which will require a decent capital investment but the results are worth it.
