WeBoost Installation (Picture Heavy)
mikej
SF Bay, California
2018 JLUR, 2023 Rivian R1T
I spent some time installing my WeBoost and routing the cables as best I could to keep them hidden. I couldn't find step by step pictures on either routing the external antenna from the rack to the inside or for routing the internal cable inside the sport bar. So I'll try and walk through the install process with plenty of pictures.
First, the outside antenna. The mast is attached to a Rhino Rack folding aerial bracket onto my Pioneer.
Jeep Wrangler JL WeBoost Installation (Picture Heavy) IMG_5349
Found an issue though, with it folded down, it's going to bounce off the platform because of the spring mount. I think I want the spring, so I'll just have to strap the antenna down. I'll need to find a better strap that can deal with the sun, though.
Jeep Wrangler JL WeBoost Installation (Picture Heavy) IMG_5353
The cable for the external antenna runs along side the hinge, and then I pulled off the weather stripping and pushed the cable inside of it.
Jeep Wrangler JL WeBoost Installation (Picture Heavy) IMG_5334
And then out around where the weatherstripping changes from the hardtop to the tub.
Jeep Wrangler JL WeBoost Installation (Picture Heavy) IMG_5338
It's tucked into the tub weatherstripping, and out through the interior panel. I have the AAL floor, so it was easy to just tuck under the platform. But if you don't have the platform, I'm sure it's easy to just tuck under the panel with the tie down rings.
Jeep Wrangler JL WeBoost Installation (Picture Heavy) IMG_5339
The WeBoost box itself is attached with heavy duty velcro to the back of my AAL drawers. (This is the carrier for the box)
Jeep Wrangler JL WeBoost Installation (Picture Heavy) IMG_5340
For power, it's just plugged into my Dometic power outlet with its cigarette lighter plug. I may change this later, but it works for now. Here's the box with the power and the external antenna plugged in.
Jeep Wrangler JL WeBoost Installation (Picture Heavy) IMG_5347
The internal antenna is attached between the rear view mirror and windshield with 3M command strips (they have cool black ones now).
Jeep Wrangler JL WeBoost Installation (Picture Heavy) IMG_5355
For hiding the wire from the internal antenna, I dropped the windshield and pushed the wire into the channel there.
Jeep Wrangler JL WeBoost Installation (Picture Heavy) IMG_5341
Then pop the plastic panel off of the passenger side sport bar.
Jeep Wrangler JL WeBoost Installation (Picture Heavy) IMG_5342
I thought about running the cable just inside the plastic, but it was going to be difficult to get back through the sound bar area, so I did the hard work to fish it through the center of the bar. And it comes back out above the rear seat.
Jeep Wrangler JL WeBoost Installation (Picture Heavy) IMG_5345
I routed the cable down through the Rhino Rack Backbone frame. And in this picture, you see that the inside antenna cable is /just/ a little too short. I bought an extension cable from WeBoost, and rather annoyingly, it's SMA but the cables for the WeBoost antennas are SMB. Sigh. So, I have adapters on the way. The extension just runs under the fender carpet and under the AAL platform.
Jeep Wrangler JL WeBoost Installation (Picture Heavy) IMG_5346
Once the adapters arrive, I'm all set!
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
Nice job! I don't think you need to go a crazy as I did but I installed a WeBoost on top of my RV and didn't want to have climb up top every time to raise it so I bought one of these.
https://www.hamradio.com/detail.cfm?pid=H0-008573
Now it is a simple toggle switch to raise and lower from inside the vehicle.
mikej
mikej
SF Bay, California
IQ_imbalance
Bob
Maryland
2022 JLU Rubicon 3.0d
OP: still happy with this? I’m contemplating going this route but since I have those wing-shaped crossbars instead of a platform I’ll probably have to get creative with mounting. Using a t-slot would be ideal, but since mine run side to side instead of front to back I don’t think that will work.
