Warn winch / auxiliary light question
Ear Responsible
Jim
2025 Rubicon x
I have a warn winch 10s zeon with the optional wiring harness attached , and would like to set up a pair of KC gravity 635 lights to my Rubicon X front bumper. Does anyone have experience running auxiliary components to the winch.? Does the winch supply power to the lights or does it only serve the purpose of an on off switch? If it can only trigger a relay I’m interested in knowing where to set that relay using as little effort and complexity as possible
Bhodi11
Chad
Raleigh, NC
392XR
If you have the 4 aux switches installed from the factory then that is how you should wire your lights up. Not sure why you would want anything wired in with the winch. Not sure what the benefit would be.
Ear Responsible
Ear Responsible
Jim
2025 Rubicon x
Thanks but don’t have the optional factory auxiliary switches
Terrymo
Terry
2023 JLURXR 3.6 ET
No first hand experience but just in case you haven’t already seen this
