Badweissenbier
Reverse is geared higher than 1st. This is why it requires more engine. And yes 4WD works fine in R. It seems harder because of the higher gearing. 1st being a lower gear has more torque multiplication therefore it’s easier. Turning tends to bind the powertrain up. On snow the tires slip relieving this. Dry pavement won’t allow as much slip causing it to fight you.
