Once upon a time there a bulletin for erroneous P0456 codes. They said anytime the battery has been disconnected you should cycle the key to the ON position for a few seconds, cycle it back off, then start the car. Some PCM logic after a battery disconnection would cause it to lock up if the key wasn't cycled once before starting the vehicle and cause it to throw that code.I agree! Mine throws the P0456 code exactly 300 miles every time after disconnecting/replacing the batteries.
After clearing the code, it’s all good until the next time I work on the batteries.
Did you find anything wrong with it or just randomly replace a part and clear faults?So instead of replacing the evap can; I replaced the gas cap. Problem solved/code cleared/light is off.
Thanks for all your responses!
To be fair I've seen a lot of bad gas caps recently. Sometimes when you tighten them if you try to loosen it you'll find it just pops right off rather than unscrewing as you'd suspect.Did you find anything wrong with it or just randomly replace a part and clear faults?
