Valve Cover Leak
flick2614
Randy
AZ
2021 Jeep JLU Rubicon Diesel
2021 JLURD, noticed a black spot running all the way down to the oil pan while under the Jeep. My mechanic took a look and confirmed a valve cover gasket was leaking. Anyone else seen one on theirs yet? Just hit 60k so going to check the warranty too.
Grayhound
Michigan
Jlurd
I had a crank shaft gasket leak 2x. Second time they replaced the harmonic balancer with the gasket. That was at about 60k miles. I’m at 93k now with no further issues. All covered under warranty.
Carguy34
Brandon
Highlands Ranch, CO
2020 JLU Diesel, 2025 JLR
I haven’t had that one. Currently around 70k miles. My charge pipe was leaking oil after the turbo. Yes, on the air side. The intake was covered in oil to the point it was leaking past the o-ring and dripping. I was told that wasn’t covered as part of the warranty and I got the opportunity to pay for it on my own. It was “normal and not significant” according to my local AutoNation Service Department. Good luck.
