USB outlet in front console?
LJDC
D.C. Area
2005 LJ, 2023 JL
Has anyone found a good place to add a cigarette-lighter sized USB outlet in the dash? These things are a bit deep, so they require space of around two inches behind the flush mount. Right now I'm fishing around on the passenger side of the center console near the stick (It's a manual), but space looks to be tight there.
I actually wired up the thing and then found that where I wanted to put it probably wouldn't fit -- luckily, it was before I drilled the hole. So now this thing is sitting in the glove box, which may become its permanent home if I can't find a better spot.
I'm trying to avoid the tray by the windshield, because I don't want wires sticking up there.
LJDC
LJDC
D.C. Area
2005 LJ, 2023 JL
What is your goal and what are you wanting to plug into it?
I need high-wattage charging for my wife's phone, tablet, etc. (Ok, for mine too.) The thing is wired and working. But I can't figure out a space to put it. I'm planning to pop off the boot for the stick to see what will *really* fit there (to its right or left), but I'm also looking for other options. I had hoped the corner of the front stack (to the right of the climate controls) would work, but that area is shallow.
jhackathorne
Denver
'21 JLUR
Most of the front center portion is pretty shallow. You might have room on the lower sides by where your knee would be.
IanNubbit
Ian
NJ
2022 JT 6MT Sport & 2023 JL 2 Door 6MT Sport
Jeep Dealer Tech
little to no room where you are wanting to put it. common location is just to the right of the current USB outlet on the dash. lot's have relocated their 12V plug there after installing the mopar trailer brake controller on the JT's
IanNubbit
Ian
NJ
Jeep Dealer Tech
Close but perfect indeed. Nice install
MeefZah
Lexington, Ohio
2020 GX460
@LJDC
There was the perfect amount of room here.
What power did you tap into to provide power to your USB? I'm doing the same thing and initially I planned to use the USB in the console to power it but apparently that only provides 5V, not 12+ needed.
MeefZah
Lexington, Ohio
2020 GX460
RatZero
Canada
2024 Willys JLU
Manufacturing @ Stellantis
LJDC
LJDC
D.C. Area
2005 LJ, 2023 JL
Thanks. I ended up gong right to battery (with a fuse) to provide power all the time.
Appreciate the tips.
Outlet is installed "upside down" so the lid flips down, and because the orientation of the USBs is wrong if they are installed the other way (IMO, since other outlets are flipped).
Just a note: USB-C doesn’t have a right side up, so it can’t be “wrong.” The writing is upside down, but the flap isn’t connected to the rest of the thing, so you can orient that however you want. I wanted it to flip down, because that was the wires that get plugged into it can be routed up,, which is away from the lid. I never plug in anything that ends up on the floor.
