Upgraded reverse light bulbs?
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
ORACLElights
Metairie, LA
I see those, but we are looking for upgraded droppins for the LED
Ok, sorry for the confusion but the factory LED lights are sealed units, there is no way to change out anything in them. If you were interested in changing the entire light out then our Flush LED tail lights feature an insanely bright reverse light.
Jeep Wrangler JL Upgraded reverse light bulbs? 5884-504_AL_1024x1024
ORACLElights
Metairie, LA
Isn't that for the aux. backups ? Why did you link to the bulb conversion use T-taps?
The reverse lights do not use t-taps. You are referring to the resistor for the turn signals.
ZellymtWillys
Mitchell
Lancaster Pa
1992 Jeep Cherokee Limited, 21 JLU Willys on order
https://dieselleds.com/
They don’t list any bulbs specific for JL’s, but they do sell the exact bulb size if you search for it. I’ve used them in all of my vehicles for a few years and they’re insanely bright and reliable.
ORACLElights
Metairie, LA
ORACLElights
Metairie, LA
You posted the Reverse bulbs and the "bulb installation guide" video.
Yes, but the "bulb installation guide" video covers multiple bulb installations on the JL. The portion of the video that references the resistor you are referring to is not related to the installation of the reverse light, it is for the turn signal LED. The LED reverse light bulbs are Plug-and-Play no need for resistors, taps, etc.
TylerV76
Tyler
Michigan
2021 JLU
That is probably one of the most misleading install videos Ive seen then.
At no point does it mention the turn signal or that the resistors are not needed for the reverse bulb. It shows how to replace the reverse bulb and immediately states to install resistors and then reinstall the housing.
Had I bought these bulbs, I would have added resistors because your video clearly instructs you to with zero mention of a turn signal.
ZellymtWillys
Mitchell
Lancaster Pa
Do you need a resistor ? Oracle install video looks good until the T-Tap resistor part at the end. The resistor is not shown or mentioned as part of the $39. Guess you have to source your own.
It was a direct swap with the OEM light bulbs. Haven’t had any issues
JL_v
Vince
Red Bluff, Ca
2018 Jeep Jl Sahara
I have these!!! And they are insanely bright! I have no complaints what so ever! Would definitely buy them again!
