Unidentified Plug
Walk2019JL
Buffalo NY
2019 Wrangler Unlimited Sport
There is a plug cluster in the lower front area in the passenger side wheel well. Can someone tell me what circuit it is associated with? I am having trouble with a tpms sensor not reading and wonder if it is associated with the tpms control module.
Spacenut
Michigan
2018 Wrangler Rubicon 2 Door
2019 tpms module should be mid jeep on top of a crossmember I believe.
Terrymo
Terry
2023 JLURXR 3.6 ET
A picture will get you some better answers
Walk2019JL
Buffalo NY
Yes, I know where the module is but I'm trying to determine where it's wire connects to provide the data back to the central data system. I see the plug previously described and wonder if that is where the tpms module is plugged to.
Terrymo
Terry
2023 JLURXR 3.6 ET
Do you mean the plug cluster in the lower front area in the passenger side rear wheel well? There’s also a main harness in the lower front area in the passenger side front wheel well.
Rear
Jeep Wrangler JL Unidentified Plug IMG_4253
Front
Jeep Wrangler JL Unidentified Plug IMG_4255
Walk2019JL
Buffalo NY
Rear
Yes pic 1, passenger side rear wheel well. Could the tpms module be plugged into that cluster?
Front
Terrymo
Terry
2023 JLURXR 3.6 ET
Walk2019JL
Buffalo NY
I don’t know but here are some wiring diagrams. The topology map of all the connectors in the second link makes it appear that it does.
https://www.jlwranglerforums.com/forum/threads/jeep-jl-wrangler-wiring-diagrams.19185/
https://www.jlwranglerforums.com/JL-Wiring-Diagrams/ENTIRE-VEHICLE-CONNECTOR-MAP.pdf
I think most reputable tire shops have the equipment to tell you if your TPMS module and sensors are functioning correctly
I have confirmed all my sensors are good but the driver side rear reading is not being picked up. It won't reset so it's likely the control module. I may unplug it and clean the connections and see if that works. Thanks for the info.
Terrymo
Terry
2023 JLURXR 3.6 ET
If you rotate another wheel to that position and drive for a bit, does it still only not display the drivers side rear?
