Turn off the lights?
SlickRicksWilly
2024 JLW (ordered)
Is there a way to have the Jeep "on" enough to listen to music and turn off all the lights?
The only thing ruining this view is that the dash lights are so bright I can see my ugly face in the mirror.
Jeep Wrangler JL Turn off the lights? 906
SlickRicksWilly
SlickRicksWilly
2024 JLW (ordered)
I think the Tazer has a dark mode option.
Thanks! But damn the man. I will check to see if Jscan has that option since I already have that. I was hoping there was a factory option. I didn't think it was likely but these things have all kinds of stupid behaviors.
Terrymo
Terry
2023 JLURXR 3.6 ET
SlickRicksWilly
SlickRicksWilly
2024 JLW (ordered)
YGBSM392
Oklahoma City
2025 Rubicon 392, 2024 2-Door Rubicon X, 2024 Mojave X
I fly da plane...
ShellNate7974
Nathan
South MS
2025 Wrangler Willys 4dr
Try using your interior light control to the left of your steering wheel. I believe it should drastically dim your Driver Information Console. At least I can on my 25 JLU.
YGBSM392
Oklahoma City
I fly da plane...
wrang_stang
TX
The dimmer switch doesn’t work when you‘re in the mode OP is (light dial all the way counter clockwise).
PhrogUSMC
Edwin
Virginia
'21 JLUR
Turn the parking lights on only. They're not bright enough to affect a sunset/dusk view outside the vehicle, and then run the dimmer switch all the way down to dim the dash.
Donack31
Don
NY
2019 Wrangler JLU Sport S
To the left of the steering wheel there's 2 wheels. One of them dims the cluster to almost black
Chris D
Phoenix, Arizona
2015 JKURHR Hydro Blue, 2019 JLUR Ocean Blue, 2025 JLURX in Mojito.
increase your power off delay to max, then need to turn on /off every 10 minutes or so?
ShellNate7974
Nathan
South MS
There has to be a way yours will dim. I believe it is a requirement because full bright will drastically reduce nighttime vision.
Every vehicle I’ve ever owned has been able to dim to almost off.
