Trans and transfer case question
Adam 4248
Washington
2018 JLS
Does the automatic trans share fluid with the transfer case. My trans died and the tech said there were metal shavings in the trans; could these migrate to the transfer case?
sf5211
Bronx N.Y.
New 2019 JL
Plumber
Definitely 2 separate units. I doubt they share fluids. I’m not 100% sure with the cooling systems that they’re not winding up together though.
Hang loose, there’s people in these rooms that know their s**t !
jessedacri
Jesse
Lake Arrowhead, CA
2019 Bright White 2dr JL Rubicon 3.6
What symptoms did you have on the trans before it went out? Curious as I've got a small noise in mine.
Adam 4248
Washington
2018 JLS
No symptoms until just before it died. At that point it would have a few second delay when shifting from park to reverse; or reverse to drive. Then it would buck like it didn’t know what gear it wanted to be in. Engine light came on and it threw some error codes related to the trans.
SecondTJ
Il
Jeep
No, they are separate. Shavings from the trans will not make into the transfer case. They do not share fluid.
Token
Toronto
2019 JLUR
No, the transfer case is separate.
There WILL be shavings in the lines and trans cooler though. If that's not properly flushed, or just straight up replaced, it could end up bad again.
JP18
J.P.
Columbia, SC
2018 JL Unlimited Rubicon
There's normally a fairly large donut shaped magnet in the transmission pan, this is to prevent any metal shavings from floating about in the transmission.
JP18
JeepCares
Auburn Hills, MI
JL
@Adam 4248
Feel free to send our team a PM with your VIN so that we can look further into this for you.
Kathryn
JeepCares
