morleyz
Added aftermarket wheels and tires with new TPMS sensors to my 2019 JLU Moab. TPMS read the new tires almost immediately and cleared any errors on the first drive. Ever since, when starting the TPMS warning light will flash for about 30 seconds and then come on solid. All 4 tires always have readings. Set all 4 tires to 38 psi and the sensors are actually spot on. No specific errors displayed on EVIC.
I've tried:
Resetting CELs with Tazer
Disconnecting negative battery cable for a bit and reconnecting.
Not sure what to try next. My cheap OBD scanner doesn't pull any TPMS codes, so I'm not even sure what the system is griping about. Any suggestions to try at home before I try a tire store with the hopes of avoiding my cranky dealer.
I've tried:
