Torque Values For Jeep JL Wrangler
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
FUEL INJECTION
Part|Nm | ft. lbs. | in. lbs. | Comments
Accelerator pedal bolts | 12 | 9 | - |
Crankshaft position sensor bolt | 12 | 9 | - |
Fuel rail bolts | 7 | - | 62 |
Oxygen sensor (downstream) | 43 | 32 | - |
Oxygen sensor (upstream) | 43 | 32 | - |
Throttle body bolts | 9 | - | 80 |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
HVAC
A/C Compressor oil drain bolt | 10 | 7 | - |
A/C Compressor shaft bolt | 14 | 10 | - |
A/C Condenser to radiator bolts | 5 | - | 45 |
Expansion valve bolts | 11 | 8 | - |
Receiver/drier to condenser bolt | 22 | 16 | - |
Refrigerant lines to A/C compressor | 20 | 15 | - |
Refrigerant lines to A/C condenser | 20 | 15 | - |
Refrigerant lines to A/C expansion valve nut | 20 | 15 | - |
Suction and liquid line assembly to body bolts | 9 | - | 80 |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
PROP SHAFT
Part |Nm |ft. lbs. | in. lbs. | Comments
Front driveshaft to front axle flange bolts | 121 | 89 | - | Do NOT reuse these fasteners. If removed, a NEW fastener MUST be installed and tightened to specifications. Torque and secure in a crisscross pattern.
Front driveshaft to transfer case flange bolts | 39 | 29 | - | Do NOT reuse these fasteners. If removed, a NEW fastener MUST be installed and tightened to specifications. Torque and secure in a crisscross pattern.
Rear driveshaft to transfer case flange bolts | 39 | 29 | - | Do NOT reuse these fasteners. If removed, a NEW fastener MUST be installed and tightened to specifications. Torque and secure in a crisscross pattern.
Rear driveshaft to rear axle flange bolts | 39 | 29 | - | Do NOT reuse these fasteners. If removed, a NEW fastener MUST be installed and tightened to specifications. Torque and secure in a crisscross pattern.
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
RESTRAINTS
B-pillar impact sensor nut | 9 | - | 80 |
Clockspring mounting screw | 6 | - | 53 |
Driver airbag to steering wheel bolts | 9 | - | 80 |
Front turning loop height adjuster mounting bolts | 45 | 33 | - |
Front impact sensor nut | 11 | 8 | - |
Front seat belt buckle bolt | 40 | 30 | - |
Front retractor pretentioner bolt | 45 | 33 | - |
Front retractor pretentioner bracket to B-pillar bolts | 26 | 19 | - |
Front retractor to B-Pillar bolt | 45 | 33 | - |
Front seat belt turning loop mounting nut | 39 | 29 | - |
Occupant restraint controller mounting nut | 11 | 8 | - |
Passenger airbag mounting bolts | 18 | 13 | - |
Seat airbag mounting nut | 10 | 7 | - |
Rear center retractor to seat frame bolt | 70 | 52 | - |
Rear center retractor to floor bolt | 70 | 52 | - |
Rear retractor to C-pillar bolt | 32 | 24 | - |
Rear retractor belt to floor nut | 48 | 35 | - |
Rear seat belt buckle to floor bolt | 70 | 52 | - |
Rear seat belt buckle to seat frame nut | 40 | 30 | - |
Rear turning loop to sport bar | 32 | 24 |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
STEERING COLUMN
Steering wheel nut | 50 | 37 | - |
Steering column nuts | 27 | 20 | - |
Intermediate shaft coupler pinch bolts | 54 | 40 | - | Do NOT reuse these fasteners. If removed, a NEW fastener MUST be installed and tightened to specifications.
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
STEERING GEAR
Adjuster screw lock nut | 45 | 33 | - |
Power steering gear bolts | 133 | 99 | - |
Power steering gear pitman shaft nut | 250 | 184 | - |
Power steering gear pressure line | 28 | 21 | - |
Power steering gear return line | 28 | 21 | - |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
STEERING LINKAGE
Drag link inner nut (at pitman arm) | 105 | 77 | - |
Drag link outer nut (at steering knuckle) | 64 | 47 | - |
Drag link adjuster clamp | 46 | 34 | - |
Tie rod end nut (at steering knuckle) | 64 | 47 | - |
Tie rod end adjuster clamp | 46 | 34 | - |
Steering damper bolt (at axle) | 80 | 59 | - |
Steering damper nut (at tie rod) | 80 | 59 | - |
Steering damper bracket nut | 75 | 55 | - |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
STEERING PUMP
Power steering pump bracket to frame | 28 | 21 | - |
Power steering pump to bracket | 8 | 6 | 71 |
Pressure line to pump | 20 | 15 | - |
Power steering hose routing bracket bolt | 6 | 5 | 53 |
Power steering fluid reservoir bolt | 6 | 5 | 53 |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
SUSPENSION (FRONT)
Part |Nm |ft. lbs .| in. lbs. | Comments
Hub and bearing bolts | 102 | 75 | - |
Hub and bearing nut | 136 | 100 | - |
Lower control arm rear nut | 140 + 145° | 103 +50° | - |
Lower control arm front nut | 140 + 145° | 103 +50° | - |
Lower ball joint nut (initial torque) | 20 | 15 | - |
Lower ball joint nut (final torque) | 45 | 33 | - |
Shock absorber lower bolt | 100 | 74 | - |
Shock absorber upper bolt | 110 | 81 | - |
Stabilizer bar bolts | 63 | 46 | - |
Stabilizer bar link upper nut | 93 | 69 | - |
Stabilizer bar link lower bolt | 80 | 59 | - |
Track bar frame nut | 70 + 115° | 52 + 115° | - |
Track bar axle bolt | 70 + 115° | 52 + 115° | - |
Upper control arm front nut | 55 + 185° | 41 + 185° | - |
Upper control arm rear bolt | 50 + 135° | 37 + 135° | - |
Upper ball joint nut | 75 | 55 | - |
SUSPENSION (REAR)
Lower control arm front bolts | 100 + 50° | 74 + 50° | - |
Lower control arm rear nut | 100 + 50° | 74 + 50° | - |
Shock absorber lower nut | 100 | 74 | - |
Stabilier bar link upper nut | 90 | 66 | - |
Stabilizer bar link lower nut | 80 | 59 | - |
Track bar nut (frame end) | 100 + 30° | 74 + 30° | - |
Track bar bolt (axle end) | 100 + 60° | 74 + 60° | - |
Upper control arm front bolt | 100 + 80° | 74 + 80° | - |
Upper control arm rear nut | 100 + 65 ° | 74 + 65° | - |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
TRANSFER CASE - FULL TIME [SELEC TRAC]
Poppet plug | 20 | 15 | - |
Drain / fill plug | 28 | 21 | - |
Case half bolts | 26 | 19 | - |
Output flange nut | 225 | 166 | - |
Transfer case to transmission bolts | 60 | 44 | - |
Shift motor actuator bolts | 12 | 9 | - |
Range position switch | 27 | 20 | - |
Extension housing bolts | 26 | 19 | - |
Range lever bolt | 30 | 22 | - |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
TRANSFER CASE - PART TIME
Shift motor (actuator) bolts | 12 | 9 | - |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
TRANSMISSION (AUTOMATIC)
Engine to bell-housing bolt | 60 | 44 | - |
Extension housing to transmission bolt | 27 | 20 | - |
Manual park release lever shaft nut | 10 | - | 89 |
Manual park release cable to transmission | 20 | 15 | - |
Manual park release grommet to bracket | 9 | - | 79 |
Manual park release lever to transmission shaft | 20 | 15 | - |
Manual park release shield to transmission | 17 | 12 | - |
Output shaft flange nut | 60 | 44 | - |
Output speed sensor bolt | 8 | - | 71 |
Park pawl lock rod guide plate bolt | 10 | - | 89 |
Park pawl shaft plug | 35 | 26 | - |
Shifter assembly bolts | 9 | - | 79 |
Transmission oil pan bolt | 10 | - | 89 |
Transmission oil pan drain plug | 9 | - | 80 |
Transmission oil fill plug | 35 | 26 | - |
Transmission oil pump housing to cover bolt | 5 + 45° | - | 44 + 45° |
Torque converter to flex plate bolt | 55 | 41 | - | Do NOT reuse these fasteners. If removed, a NEW fastener MUST be installed and tightened to specifications. NOTE: If old fastener must be reused, Loc-Tite must be applied to the threads.
Transmission mount to adapater | 30 | 22 | - |
Shift lever assembly to floor pan bolts | 8 | - | 70 |
Transmission shift knob | 2 | - | 17 |
Transfer case shift knob | 2 | - | 17 |
Manual park release to shift lever assembly | 8 | - | 70 |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
TRANSMISSION (MANUAL)
Drain plug | 30 | 22 | - |
Fill plug | 30 | 22 | - |
Shifter base to floor assembly bolts | 8 | - | 70 |
Control shaft cover assembly bolts | 25 | 18 | - |
Shift lever bolt | 8 | - | 70 |
Output speed sensor bolt | 8 | - | 70 |
Transmission stroke sensor bolts | 25 | 18 | - |
Input shaft retainer bolts | 9 | - | 80 |
Clutch release bearing retainer bolts | 10 | - | 88 |
Output shaft lock nut | - | - | - |
Shift fork detent bolts | 25 | 18 | - |
Shift fork support bolts | 8 | - | 71 |
Reverse idler gear shaft bolts | 20 | 15 | - |
Countershaft bolt | 100 | 74 | - |
Transmission case bolts | 40 | 30 | - |
Transmission oil separator bolts | - | - | - |
Transmission shift guide plate bolts | - | - | - |
Transmission mount bolts | 47 | 35 | - |
Shift cable retaining bracket | 22 | 16 | - |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
WHEELS & TIRES
Spare tire carrier bolt | 17.5 | 13 | - |
Spare tire carrier lug nut | 80 | 59 | - |
Tire pressure sensor nut | 1.4 | - | 12 |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
WHEEL BOLTS
| Torque | Lug Bolt Size | Socket Size | Hub Size
Sport | 130 ft. lbs. [176 Nm] | M14 x 1.50 | 22 mm | 71.5 mm
Sahara | 130 ft. lbs. [176 Nm] | M14 x 1.50 | 22 mm | 71.5 mm
Rubicon | 130 ft. lbs. [176 Nm] | M14 x 1.50 | 22 mm | 71.5 mm
