Torque Values For Jeep JL Wrangler
Bilymac
Bill
Auburn, CA
2006 Ram 2500, 2017 Chevy Tahoe, 2017 Harley Street Glide Special, 2019 Jeep JLRU
Great info.....thanks for posting Jay.
dapipp
NW Idaho
2006 Jeep Wrangler X (TJ), 2006 Jeep Wrangler Unlimited (LJ), 2019 Jeep Wrangler Rubicon (JL)
Here is what I use. On the right side I just highlight the fields in yellow of things I have worked on and what values I used.
dapipp
NW Idaho
How about providing links to the different sources, maybe as a group we can get to the bottom of this.
Edited post to make clearer, I think faster than I can type.
Fastmover
Bob
Ottawa
2019 2.0L Billet JLR: Ordered 1/9. Delivered 2/13. Picked up 3/5.
What does the degrees spec mean? I don't have knowledge of working on suspension components.
Lower control arm rear nut 74 +50°
Chocolate Thunder
Jeremy
74 ft/lbs then turn another 50 degrees or rotation. Yeah, those suck.
blnewt
New Mexico
Just ask @cosine he knows!
At least you can get your breaker bar and finish them off if your torque wrench will be maxed out close to that listed initial torque value :)
And x10 on the thanks Jay, nice job!
vap
Fremont, CA
2019 JLUR
There are many differences in torque values between this (offline USB version of the service manual) and an online service manual (available via Mopar tech authority subscription). While most of the differences are withing 10%, which is not good, but usually not dangerous, some differences are on the extreme end:
For example, old offline version:
Left engine mount isolator to engine block bolts -- 41 ft lbs
Left engine mount isolator to frame nuts -- 85 ft lbs
Online version (as captured 3 months ago):
Left Engine Mount Isolator to Engine Block Bolts -- 48 ft lbs
Left Engine Mount Isolator to Frame Nuts -- 36 ft lbs
Almost 2.5 times difference for the same nut :facepalm:
dapipp
NW Idaho
If I had to make an uneducated guess, I would say those numbers are a result of several things.
1) new vehicle discovery pains
2) fat fingers - probably not
I would think as time goes on torque values will change as issues are found and the vehicle matures.
Also, over torqueing is just as bad as under torqueing.
As for the example above it appears, to me, that one number was refined and the over “mistake” was adjusted.
I do not have access to the online version to adjust my documentation but if somebody can provide the data I will update it.
