Tire pressure display disappeared
trackfast20
Kyle
Kansas
Gladiator Rubicon
Hi guys. Sorry to chime in so late here, but I'm having the same issue where my tire sensor screen isn't there anymore after getting new stuff put on the jeep including the tazer mini. The shop said that the sensors were installed with the new tires and that they should be working. How did you fix the solution w/ the Tazer Mini? I went in and made sure it said "yes" and I even changed the press on front and back. But still doesn't show. Do I need to unmarry and then remarry thing thing?
trackfast20
Kyle
Kansas
Gladiator Rubicon
How would I trouble shoot the TPMS issue after unmarrying it?
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
Once you unmarry the Tazer do a full reboot of the system and then drive over to DT or who ever did the install and have them scan all the sensors to make sure they are reading and then go from there, it’s doubtful the body control module is bad.
Also when you say tire pressure is not there are there dashed lines by each wheel on the display or is the entire display not there, if the entire display is gone it could be Tazer related so it’s best to unmarry it and make sure to reboot the system and do a few cycles to ensure the Tazer is clear
trackfast20
Kyle
Kansas
Gladiator Rubicon
The screen for seeing the tire pressure is not active. Meaning I can see it on the apps, but it's greyed out. Also on the driver dash it's no longer available.
I did have new 3" lift, gears, and tires replaced + Tazer mini for speed and gears to be correct. Once I got it back the tire pressure screen was no longer accessible. The shop stated that the sensors were still good and installed on the new tires. So I'm guessing it has to do with the Tazer mini.
WranglerMan
Will
Greenfield Indiana
You need to unmarry the Tazer then do a few cycles of the system to see if it’s all back normal then we can look into other things that can possibly be causing this
trackfast20
Kyle
Kansas
Gladiator Rubicon
Hey guys, Update. The tire pressure screen is back. I just adjusted the air pressure on the tazer mini a couple of times and it now shows back up. Not sure exactly why; but it does work now. TY for the help!
MikeJLURubi
Chillicothe, Ohio
2018 Jeep Wrangler JLU Rubicon
Medicolegal Death Investigator
I am having the same issue. My TPMS isn't showing at at. My Taser is marked YES. I unmarried the Taser and still not in cluster. What did you have to do to get it back?
Thanks
onepluto
Earth
Tesla Y
Thanks
What version are you running on the Taser? I had the same issue but after an upgrade it came back. I'm running 11.2.4 and was about to upgrade to 11.2.5 but may wait for the air pressure update in 11.2.6 where the blinkers will flash once you air up to at least the minimum.
MikeJLURubi
Chillicothe, Ohio
Actually I did another hard full re-boot and they are back. Technology, huh!
Thanks for responding.
LisaK
US
Jeep Wrangler 4xe
Hi WXman,
Let us know how your appointment goes. You may send us a private message if you need any assistance with this concern.
Lydia
Jeep Social Care Specialist
Today I noticed that the readout for the tire pressure at each corner of the vehicle is gone. Formerly this display was located under "vehicle information" but now it is missing. Anybody else seen this? Odd...
This happened to me as well, right after I brought my Jeep in for service. They also told me I need new tires when my lease is up in only two months. Seems very fishy to me!
LisaK
US
Jeep Wrangler 4xe
How did you get the TPMS to display again?
