Tips for Antenna Removal?
TrailMax
Max
Arkansas
2023 Wrangler High Altitude 4xe
I used heat shrink tubing to cover mine.
Not only achieved the goal of having a black antenna, but also cuts down noise/potential paint scratching when the antenna hits the cab.
73TAWM
Troy
Missouri
21 JLU RUBICON 2.0T 3"LIFT 37's
Lumber Sales
This probably sounds stupid, because it is. Are you turning the silver antenna or are you trying to turn the black circle piece?
AZHellaYellaGirl
AZHellaYellaGirl
Danica
Scottsdale, Arizona
2021 Wrangler Unlimited Sport Altitude 2.0L
Army Events & Yoga Teacher
Fair question...tbh i was waiting for someone to ask.
But it IS the silver antenna that I am trying to turn
UncleArt
Arty
Western Washington
www.instagram.com
2022 Wrangler JLR 3.6l, 6MT, 4.88s
I recall mine having some resistance removing, but it wasn’t that difficult. You could try a heat gun to soften up the locktite (if that is what is on the threads). Be careful not to heat up the fender paint.
I replaced mine with this black one from Amazon:
https://a.co/d/bRE6dTB
It has held up well for 1-1/2 years now…
  • Like
Reactions: AFD
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
Other than a heat gun, using a soldering iron to heat up the metal antenna should help to get any Loctite threadlocker gel loose. Might end up scorching wherever you touch, though. Using a lighter might also work, but is also more likely to scorch the base as well.
Upnarms
AZ
2019 JLUR, 2003 TJ X
This ^
No need to remove
AZHellaYellaGirl
AZHellaYellaGirl
Danica
Scottsdale, Arizona
This ^
No need to remove
I am thinking that I'll try it....looks like either Lowes or Home Depot will get a visit so I can actually see the different sizing options. I'm one of those weirdos that is OCD Type A Brain specific and can't just order on a guess lol
BillyToronto
Billy
Toronto, Canada
2019 JL 2 Door Sport, 2000 TJ
I can't believe you're letting the antenna win !
AZHellaYellaGirl > stubborn JL antenna
(Put a small length of pipe over the proper wrench and try unscrewing with more leverage, after you've sprayed with penetrating oil and giving it a light hit with a hammer, not a wild swing, gentle rap or two).
Billy
3TV
Southwest USA
2022 JLUR 392, 2025 JLR
Commonly used motto when doing Jeep modifications: "If it jams, force it. If it breaks, it needed replaced anyway". More force will likely solve the problem. The cheater pipe advise above is good.
Wbino
NJ
Since you're keeping it, is it possible to paint it while on?🎨🖌
Midwestjeepguy
Midwest
2018 Jeep Wrangler JLUR
Crazy it won't budge even with locking pliers. When you do get it off I like this antenna. I tried the Bronco antenna and while it looks good in the rubberized black it was too whippy for me. At highway speed it would bend nearly touching the door mirror and would hit it in wind gusts. I also tried some much smaller amazon antennas but reception sucked. This antenna is shorter than the OEM antenna, it's a rubberized black coating, has held up for a year in the sun and multiple washes (still looks new), and has great reception.
https://www.amazon.com/dp/B08ZYJZH4F?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_2&th=1
If I remember right I may have had to get an antenna mount adapter because that one doesn't come with the right size. Here's a kit I bought:
https://www.amazon.com/dp/B0BV1VZ38G?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_2&th=1
