Swadehead
The part number for the wheels I ordered is 1059059. That should be the two tone ones with -12 offset, 5x5 bolt pattern and 4.5” backspacing, correct?
On the 1059059 wheels it looks like we have over 40 on hand at the time of typing this, so you're good to go there. Correct, they are -12 offset 5x5 with 4.5 backspacing.The part number for the wheels I ordered is 1059059. That should be the two tone ones with -12 offset, 5x5 bolt pattern and 4.5” backspacing, correct?
you have to purchase separately i do believeMight be a silly question, but the description says it’s compatible with the deflator valves. Does it come with the valves pre installed?
Good question; the deflator valves should come pre installed in the wheels.Might be a silly question, but the description says it’s compatible with the deflator valves. Does it come with the valves pre installed?
This is true for the original style Nomad wheels we have, which came in both "base" without the valve and the "deluxe" with the valve. On the new Split Nomads and Olympus beadlocks they will come with the deflator valves as standard.you have to purchase separately i do believe
