Tazer Mini Sway Bar Control?
rkruz3
jlu Rubicon 2024
I can get a straight answer out of Z Automotive, and their manual is no help.
I understand the function to disconnect the Swaybar in 2WD, and it reconnects at 30 MPH.
.................but..........
What is Swaykill? What does it do?
There is no explanation in the manual other then it is assigned a button on the steering wheel..
Does Swaykill simply disconnect the swaybar all the time in all modes, 2, 4 High, 4 Low and not reconnect at any speed?
jav_eee
2021 JTR
It would seem like it, based on their literature, but mine never stays fully disconnected. However, I do notice it is much quicker/easier to to disengage it by using the swaykill button vs using the gem sway bar button.
THAW
Foster
23 JL4DrRubicon
Yes, can confirm.
A second (mapped) button push initiates a reconnect, otherwise reconnect is automatically initiated at next Jeep startup.
rkruz3
jlu Rubicon 2024
Yes, can confirm.
Excellent. THank you. Does the dash button still still when reconnecting/disconnecting and stay solid on when connected?
THAW
Foster
23 JL4DrRubicon
I'm not sure I understand your question.
The dash button will reconnect swaykill initiated disconnects, and the dash button light indicates actual disconnect state regardless of swaykill initiation.
