WranglerMan
- Will
- May 8, 2018
- Greenfield Indiana
- 2018 Wrangler JLU Sahara
- Occupation
- Retired
- Vehicle Showcase
- 1
I have no idea what the Vendor sent, they were branded as OEM on the second set and even after the install it took them some time to sync up as in the fronts took like 15 mins and the rears did not sync up until the next morning after the install, the install vendor said it could take as little as 20 mins and as long as a day but I had never heard that before.im going through the same thing, with all tires pressure read but the tpms light on. Do u mind telling me what sensor finally worked for u? the one i have is the Schrader 20398.
One other thing to consider is if you are reading all pressures and the idiot light is on it may be due to pressures being below the low limit from the factory, if you have a Tazer you can change those set points and if not you will have to live with the light being on.
My current cold pressure is 30lbs and the factory alarm is set at 35 so when pressure drops to 30 the light will come on so I set my alarm to 30 and won’t get the light until 25.
My rotation is coming up soon and we will see how the spare does being added to the mix.
