Tailgate rubber flaps
shooting4625
Colin
Utah
Coming soon 2023 2door wrangler Rubicon
Can anyone give me information or reasoning for the rubber flaps under the spare tire carrier, it was on our 08 JK and is on our 2023 rubicon JL’s, just wondering if it helps cause the small dust layer that gets onto the inside of the tailgate
Terrymo
Terry
2023 JLURXR 3.6 ET
Cabin pressure ventilation when driving with top on and a window down. Or shutting a door with the top on and windows closed. Also to help prevent buildup of carbon monoxide.
shooting4625
Colin
Utah
Carbon monoxide build up ?
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
The flaps let air out but not in. So if you do have an exhaust leak that gets in the cabin the airflow will take it away from the passengers, into the cargo area and out the tailgate.
It's also helpful if someone farts.
Radioman
Kent
Roseville, CA
2017 Toyota Highlander, 2020 Ford Ranger, 2025 Jeep Rubicon
Retired Public Safety Communications Manager
All cars have a vent somewhere, in pickups its between the cab and bed. Allows for easier closing of the doors when the windows are closed. Also exhausts air that is blown in by the HVAC system.
Wulfgott
Riverside, CA
2020 PUNK'N 2.0L Turbo JLUR
Meat popsicle
As Reinan stated... " It's also helpful if someone farts. ".
For me it is a REQUIRED component of the EFGR (Emergency Fecal Gas Relief) system. Really Really important if you have a passenger whom fails to mention that they had a release.
Simply boost the fan speed of the environmental controls... I also tend to immediately depressurize the cabin using the closest window to the party whom caused the problem.
dbudday
Pittsburgh, PA
2020 Jeep Wrangler Unlimited Sport S
Depressurization is key!
autotragic
the cornbelt
'21 JLR 6MT
Every car has those, you just don't normally see them. They're just to keep pressure from building up in the cabin. They're supposed to be one way as they are meant to let air out but not let air in. It helps with your HVAC and closing the doors with all your windows up. If it doesn't work right then it's a pain in the butt to close your doors I've had a vehicle do that before. To get the doors shut I always had to crack a window. Otherwise the harder you slamed the door the harder the air pressure pushed back on it and made it harder to close. You definitely don't want to mess with that.
