Stock Bumper?
LugNutJL
Keith
NorCal
2024 Wragler JL Rubicon 4DR
Is the 2024 stock steel bumper able to have the “wings” removed so it turns the bumper into a “mid-width” bumper? See diagram ie. remove part #15 on both sides.
Jeep Wrangler JL Stock Bumper? IMG_1010
Overkill
Paris, IL
Rubicon392.com
2024 392;2002 TJ Sport;2005 GMC 2500HD;1969 Camaro (x2);1974 Chevy Cheyenne K20
Information Technology
Yes, they can be removed.
Jeep Wrangler JL Stock Bumper? 20240413_132342
LugNutJL
LugNutJL
Keith
NorCal
Awesome thanks for the photo!!!
LugNutJL
LugNutJL
Keith
NorCal
One other question, can part #16 (Madonna Protrusions) be swapped out or is there some purpose to direct the fog light beam as to why the stick out more than say on @Overkill 's bumper? This is the Jeep I am looking at getting to replace my 21' 2Dr Rubicon. Appreciate everyones help!
Jeep Wrangler JL Stock Bumper? Screenshot 2024-06-12 at 11.08.39 AM
UTME
T
2024 Rubicon-X Unlimited
Yes ends removed.
Jeep Wrangler JL Stock Bumper? IMG_2261
Remorseless
NC
You can pull off the plastic bezels and cut down the metal crush can underneath the Madonna tits. Then, you can put the shorter plastic bezels on and you're good to go.
LugNutJL
LugNutJL
Keith
NorCal
Ok, so sounds like a mod vs purchasing a different bezel?
Remorseless
NC
Yep. The bezels are that extended because there's a different steel structure under there. But, the structure is basically the same as the normal steel bumper structure, but with a secondary crush can welded on. You can either disassemble the bumper and swap out the crush can structure or cut it down. Cutting it down is by far the easier way as you're just cutting the secondary crush can off of the first.
LugNutJL
LugNutJL
Keith
NorCal
Great thanks for the explanation! I'll have to take a look once I get it.
Overkill
Paris, IL
Rubicon392.com
They don't have a purpose as far as the light beam goes. I think the thought is that it was supposed to provide some minor crash protection for the factory installed winch. But since people have installed winches in the factory bumper since they came out with this bumper style, there wouldn't be any issue with doing the steps that @Remorseless listed.
Remorseless
NC
Video detailing this that got posted on the forums a bit ago:
