Stiff brake pedal after extended line install
XX4XEXX
JD
Ca
2021 Rubicon
Mechanical Engineer
Anyone want to take a stabb at this. I installed a synergy extended line kit front and rear. After bleeding brakes the pedal is super stiff and jeep has a hard time stopping. I'm thinking I just need to bleed few more times (Z) but was wondering if you guys have seen this before. Usually it's a soft pedal.
Used Mopar dot 3.
Thanks
XX4XEXX
XX4XEXX
JD
Ca
2021 Rubicon
Mechanical Engineer
Made some lead way. Found I set off ABS code on low fluid. Reset code now brakes are perfect stop sharper with the kit.
Next question does anyone know if the ABS and brake error light will go away on its own after awhile?
XX4XEXX
XX4XEXX
JD
Ca
2021 Rubicon
Mechanical Engineer
Figured this one out as well. Cycle run motor twice codes disappear. Thanks guys ?
