Steering Wheel Radio Controls
HighvelJL
Herb
coral springs
2024 JLU Rubicon
Just purchased a 2024 Rubicon. Coming from a a 2013 Rubicon. Is there a way to have the station buttons on the left side of the steering wheel switch the pre-sets instead of one channel to the next on SiriusXM?
Barney392
High Desert So Cal / Lake Havasu, AZ
On my 2022 there is a place in the Uconnect where you can select channels you do not want to use (skip). Look in the SiriusXM section in settings.
Heimkehr
Pennsylvania
2021 JLU 2.0T
Using my '21 as an example: the left rear-side rocker switch will advance to the next or the preceding station, depending on whether the top or bottom part of the rocker is pressed. Pressing the small center button will advance you from one preset station to the next.
I can't say this is how your '24 will work, but I'm also presuming the switch functioning itself hasn't changed between model years. If it has, then it has.
HighvelJL
Herb
coral springs
2024 JLU Rubicon
I did not realize there is a center button. I will try that. Thanks!!
Dgr401
Dennis
Rhode Island
2020 Wrangler JL Sport S - Granite Crystal
The center button on the right side of the steering wheel will toggle through am, fm, phone, Sirius etc.
