SOT Sky One Touch top leaking
Burtv
Burt
Escalon
2020 JLU Rubicon, 2019 JLU Rubicon, 1978 CJ7, Polaris Ranger XP, Mercedes S580
“I bought a 2019 Jeep JLUR with the Sky One-Touch top. At the rear, where the canvas meets the frame, there is a gap between the canvas and the rubber weather seal, and it’s causing a leak. The gap runs the full length across the back. I can actually slide an envelope through the space between the seal and the canvas.
Has anyone else had this problem? Does anyone know whether the canvas or rear portion of the top can be adjusted or tightened so it fits more snugly against the weather seal?”
Jeep Wrangler JL SOT Sky One Touch top leaking IMG_7019
Jeep Wrangler JL SOT Sky One Touch top leaking IMG_7023
Jeep Wrangler JL SOT Sky One Touch top leaking IMG_7018
Jeep Wrangler JL SOT Sky One Touch top leaking IMG_7020
Gregj
Greg
West Texas
What is the story on the Jeep? That top is all kinds of crooked, I would loosen all the bolts that hold it down and see if you can move it around to close the gaps. It looks like the top sliding section is “racked” ie it is a parallelogram instead of square.
In your first picture the line up of the top and back glass section looks good on the right side but the left side is way too far apart.
Gregj
Burtv
Burtv
Burt
Escalon
Gregj
It does look out of alignment but I'm new to these roofs and not sure about that, but its worth trying and loosening the bolts to move it around if possible, I was assuming there would not have any movement at all with the 8 or 10 bolts but I'll give it a try and find out.
Any other suggestions are appreciated from anyone.
Gregj
Greg
West Texas
You can see a mark in the weather strip in the left rear where it was/should be. How do the quarter windows line up?
Gregj
Burtv
Burtv
Burt
Escalon
Gregj
The drivers side window fits good and seems aligned, the passenger side fits loose and I added a little weather seal were the upper right corner of the window meets the back door. There is an indentation (factory) in the top were the door meets the top and the quarter window and I needed to add the seal there because with the door closed it doesn't put enough pressure on the factory seal. I can take pics when it stops raining here, I have it cover with a plastic tarp for now.
TheBirdie72
Rhode Island
2021 Jeep Wrangler Freedom Edition 2 Door
I didn’t know the SOT was avail on 2019 wranglers… 🤷‍♂️ That was only the second year of the JL…
bcupton
Bob
St Louis Mo
25 Wrangler Rubicon X
Retired Navy
I have the SOT on my 25’ JLUR-X. I know what the salesman said how it could be used. But I never open or close it unless I’m flat no hills, no curves, no rough terrain. Again just me.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
I see some blue painters tape... Has this been in a body shop?
Burtv
Burtv
Burt
Escalon
I'm not sure what you see is blue tape but it very well may be. Its raining here and I can't inspect but regardless, I do believe the Jeep has had some body work done. I've only owned the Jeep for a few months. It did indicate some body damage but not specific in the Carfax report.
Burtv
Burtv
Burt
Escalon
Gregj
After suggesting loosening the bolts and trying to realign the top. I started to do this when I discovered many of the bolts securing the SOT to the roof top were missing, so misalignment is probable, now I need to find a new set of those bolts because I have seen video that those bolts, 10 on each side, are in various lengths. Where to find a new bolt set?
Gregj
Greg
West Texas
The longer of the screws is
6513815AA
The shorter is
6512209AA
In total you need eight of each, four per side. The first one and the last three at the back are the shorter ones and the long ones go in between them.
Gregj
Burtv
Burtv
Burt
Escalon
6513815AA
The shorter is
6512209AA
Gregj
Alright thanks very much for supplying the part numbers, I ordered a full set. Sometimes finding the right part and number is more time consuming that installing the part, hopefully this will resolve the issues with this SOT, thanks again appreciate the help very much.
