Solved: Passenger Side Rattle
RRJeeper57
Rio Rico,Arizona
2019 JL 2 Door
It sounds like it's coming from inside the Jeep. It's just hard to try and pin point the noise since it's on the passenger side. I've tried holding down the visor and that doesn't do it
On my Jeep the drivers door squeak was coming from the outer door lip seal, I applied 3in1 oil with my finger on the 3\8 high lip seal and elimin.ated the squeak. GM sells a lube for door seals for around $14.00 on amazon. The noise appeared to come from inside the door, but the clue was when I opened the door, the noise would go away, it took me about three weeks to pinpoint the source of the squeak
DavidArmen
Los Angeles, CA
2021 JLUR
I wasn’t aware the JL doors had more than one rubber gasket seal? Can you please elaborate what you mean by outer door lip seal if the door has only one rubber gasket? Thanks!
