Soft top rattle
robaw
Rob
Iowa
Yea, with those rollers and attaching that plastic exoskeleton, something is bound to rattle a bit. (I have dual top, so I've added/removed the soft top frame a couple times now. I'm sure that doesn't help lol)
Me too - I've pretty much given up on it. No matter what "mode" I'm in with the soft top (full up / full down / sunrider / safari) something is making noise I don't really like. It's a Jeep thing I guess...
mlebofsky
Denver, CO
2019 JL Rubicon softtop
Director, DoD
Yep. Little wheels in the tracks have too much side-to-side play and rattle ...
mlebofsky
Denver, CO
Director, DoD
As a test, I just wrapped my little wheels with black electrical tape and trimmed the tape so the wheels roll freely. The front face and the wheel surface are covered. It not only cushions the hard plastic on hard plastic sound, but it takes up some of the slop space. I'll leave it like this for a few days and see if it quiets things up. If so, I may then progress to a simple paint on rubberized coating for the wheels ....
mlebofsky
Denver, CO
Director, DoD
FIXED. Honestly, I was amazed how quiet it is now.
I'll see how it wears over the next month and might just leave well enough alone. Or I could take the tape off and try a rubber paint on coating ...
EnjoyLife
Darren
O'Fallon, MO
2013 Camaro SS, 2018 Jeep Grand Cherokee Larado
I wonder if Plastidip would work
Mikejd1
Wrangler JL
Nice! I’ll try this. I, sick of dealing with the Velcro straps already!
mlebofsky
Denver, CO
Director, DoD
Something that:
1) is thick enough to take up a little space
2) will remain rubbery enough not to make a banging noise inside the track
3) durable enough to handle rolling in the track every so often
Mikejd1
Wrangler JL
So I just did the electric tap and it worked brilliantly!! Absolutely genius !!! :)
mlebofsky
Denver, CO
Director, DoD
OP will never get a job with FCA he is way to smart
I didn't check, but are the little wheels riveted on or do they use a real little screw? If they are screwed on, I bet we can find wheels that are just a touch wider and taller .....
Mikejd1
Wrangler JL
Now it rattles and makes more noise with the soft top up! Can’t win :(
mlebofsky
Denver, CO
Director, DoD
I haven't tried it with the top up, but I never had a rattle noises with the top up.
Mikejd1
Wrangler JL
i fixed it....apparently the electric tape was too large and whether it was wind coming in, or the tape rubbing against the plastic, that was the culprit of the noise. I cut it down a bit more and tightened the tape a bit
Mikejd1
Wrangler JL
sound is back again! it's def the tape...moving around in there when the top is up, or something. Can you take a pic of your wheels?
mlebofsky
Denver, CO
Director, DoD
I am on travel for a couple of days with no access to the Jeep. Perhaps someone can look at the little wheels in the track and see if they are screwed on or permanently mounted to the black bracket. We need to source slightly softer wheels that are a little wider and taller so the roll in the track without all the clanging.
My tape is still holding up and things are quiet, but I realized this was a temp solution to test the theory.
