soft top corner post
Jiggs1960
Curt
Atglen, Pa
2022 Jeep Wrangler Willys, 2022 Chevy Colorado
I'll do my best to describe the situation, and hopefully, you'll be able to follow.
We have a 2-dr Wrangler with the factory soft top. In the summer, we will often open the top to the first position (not all the way open), and remove the back window (leaving the side windows in place). The cornerposts have a tab at the base that slices into a notch (however, it does not "snap" into place), and is esentially held into place by the rear window. When the rear window is removed, there is nothing preventing them from rotating outward, and potentially becoming "detached". I like to be able to remove the rear window for the increased air-flow. is there something that can be done to hold the corner posts in place in this situation? Are they supposed to actually "snap" into place at the bottom, and just need a good whack?
Thanks
Tangokilo
Tom
Southwest Michigan
1972 Oldsmobile 442, 2001 4runner, 2010 Honda Accord V6 Coupe, 2011 VW Golf, 1969 Triump T100 MC and 2018 JLU Sport S
I believe I have read here some cases of side widows coming loose because as you describe they are not positively retained once the back window is out. You could add a secondary restraint like a piece of parachute cord tied between the two. Maybe some stick on Velcro tape carefully placed somewhere to do the same. Or just remove the side widows works too - that's what I do. Safari mode...
Terpsmandan
Penn Yan
Because I lost a window on the highway last summer, I drilled 1/4" hole in the plastic support panel in the window at the bottom near the tailgate bar, and another in the tailgate bar. When I put the top up I ziptie the window to the tailgate bar so I do not loose it again. Thinking that could work for you as well.
Jiggs1960
Jiggs1960
Curt
Atglen, Pa
thanks for the reply. I considered connecting the two with a cord like you suggested, my main concern was that they aren't supposed to actually "snap" into place, and I was missing something. If were out, and decide to open it up, it's a lot easier to just take out the rear window and put it in the storage bag that we keep hanging in the back, and leave the two side windows in.
thanks again.
Mocopo
Arizona
Mine also does not have any noticeable "snap," and feels like it would likely fly off at a high enough speed. My solution is just take the windows out too. i've never felt like it adds much time or effort, when you can yank all 3 out in less than 2 min.
If you do try a different solution, would be interested in seeing what you come up with.
JHTS
John & Holly
Hope Mills NC
21 Gecko JLU Freedom, 20 Punk'n JL Sport S, 91 Mustang GT, 25 Ranger XL
John - US Army Ret/DA Civilian
The soft top is not designed for operation with the rear window removed and side windows on. Either all three on or all three off per the owners manual. There is no snap as the rear window is what secures the side windows.
Jiggs1960
Jiggs1960
Curt
Atglen, Pa
thanks for the reply. I guess someday, I really do need to read my owners manual front-to-back.
have a great day.
Heimkehr
Pennsylvania
2021 JLU 2.0T
+1 regarding what @JHTS mentioned. The rear window was designed to provide an important retention function for the side windows when all are installed.
You're correct, Curt: The tabs on the vertical stiffener pieces of the side windows are intended to have a press fit only into the corresponding tabs on the bodywork, etc. Unless the tabs are positioned and seated correctly, the risk of loss of the side windows when driving is heightened. This risk is doubled when the rear window itself is intentionally absent.
I do miss the roll-up feature of the rear window on my YJ for precisely the benefit that that configuration provided: a pleasant increase in air flow on warm days. It's just something that isn't easily or safely mimicked on the JL unless I flip the top back into the Sunrider position, or lower it completely.
Joe's_Roxy
Arkansas
2018 JL Rubicon, 2009 JK Sport, 2006 LJ Sport
Quality Manager
I took a couple of small pieces of expanded metal (it was what I had on hand at the time) and bent them to form a hook. I attached them together with a piece of nylon cord. I set the cord tight enough to hold the side windows in place.
Jeep Wrangler JL soft top corner post 1682616919162
To install the kit, I slide it in from the top of the back wind channels after removing the back window. I then push it down to the bottom of the channel. I typically have the tailgate piece in place and will put the rope inside the channel to help secure it.
Jeep Wrangler JL soft top corner post 1682616955039
Have run this set up on the highway at speed and around town. The rope keeps the side windows in place as if the back window was in place.
Jiggs1960
Jiggs1960
Curt
Atglen, Pa
thanks for the reply. for me, it's so much easier to remove just the rear waindow if you're out running around. Jeep needs to re-think their design to allow for this.
have a great day.
Jiggs1960
Jiggs1960
Curt
Atglen, Pa
that looks like it might be worth trying. easy enough to make, and easy enough to put in place when you need it.
thanks
Joe's_Roxy
Arkansas
Quality Manager
thanks
Yes to both! :CWL: :CWL:
