Smittybilt Stryker bumper - help
vsivanandam
vsivanandam
Vijay
olympia WA
2019 JL Rubicon
it’s a rough country with DRL.
As for the spacer, it’s just a flat rectangle that goes on between the frame horns and the main winch plate thing.
awesome ... thank you very much
DigitalDiem
Capn
TN
2018 JLU
they are oculus leds. The stock steel bumper led mounts didn’t work with the bumper mounts.
Gotcha...I had to perform some creative engineering to get my OE LEDs to fit. Essentially had to move them as far out as possible with some Standoffs on the mounts. Quite Tedious even then there is only about 1/8th inch between Wire plug and winch.
DigitalDiem
Capn
TN
2018 JLU
You wouldn't by chance know if these are shorter in depth than the OE LEDs would you? Though mine work I know eventually there are going to be problems.
conFUcius
Stephen
North Carolina
2024 Supra MKV 3.0, 2024 392 JLUR
Medical Affairs
Theaudiowave
Ricardo
Socal
2022 Jeep Wrangler sport
My solution is order pair of non-led fog lights off eBay that look like this ... Ill eventually swap out yellow Led bulbs or upgrade to morimoto fog light later on, but I need the hardware off the non -led fogs
So out of curiosity.. are there any brackets that are supposed to come with the whole bumper/ bumper assembly ? I only ask cause I just ran into this dilemma in my 2022 Jlu sport with ( non led fog lights )
Djhyper66
JOHN
Corona Ca.
Jeep Wrangler 2020 JL
Post a picture of what’s wrong ???
moparcruiser
2021 Wrangler Sport S 80th Anniversary
I don’t think there is any difference in the size of the two winches. Note that the Clearance issues I had were more to do with the grill than the fogs. Make sure you use the spacers that comes with the bumper. It’s not in the instructions...
WHat brand and model 13" light bar did you use in the over-rider???
