Rubicon inner fender liner removal issues
stl jeep
St Louis
2024 JLU Rubicon X
I’m having some issues getting my fender liners removed. It looks like the liner sits underneath the flare extensions. I’ve tried drilling the metal rivets out, but it’s a total struggle to actually get them removed. The one I could get out left a giant hole, so I’m worried I won’t be able to replace it. I’m just trying to get access behind the liner and replace it when I’m done. Any thoughts?
Jeep Wrangler JL Rubicon inner fender liner removal issues IMG_9490
YBABRAT
VIRGINIA
2019 2 Door Rubicon X Wannabe
None... but it pays well.
I think you have listened to too many know it alls on YouTube. My Rubicon's inner fenders pull out when all the screwed in fasteners are removed. Pulled the front passenger side to remove aux battery. You need to tug good to pull from the rivets.
You can return the inner fender by sliding in place and the rivets will hold it like before.
Only one YouTube vid shows a woman demonstrating the technique... no rivet replacement needed.
stl jeep
St Louis
2024 JLU Rubicon X
The rivets go through the flare extension and the inner liner. I can see that with the couple I got off.
I’m hoping someone has some tips on getting those rivets out. The ones I have out are bulging pretty good and I want to make sure I can get rivets back in.
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
First of all, not all of the rivets go through the inner fender liner. It has notches around some of them, at least on my '21.
I removed my rivets by taking a blunt awl to the center pin of the rivet and pushing hard. This breaks the rivet so it can be pulled out. They're not reuseable anyway so there's no harm in it and it shouldn't damage the inner or outer fenders this way. Just have new rivets and a plastic riveter on hand before you start. You'll need them to reattach.
stl jeep
St Louis
2024 JLU Rubicon X
Thanks for the response. As far as I can tell, it looks like the rivets go through the inner liner on my 24. I’ll probably just get aggressive with the removal. If it goes bad, maybe it’s time for some aftermarket aluminum liners anyway…
BobW
Bob
Ventura County
2018 JLUR 6sp MT; 2019 GC; 2021 Lego JLR
It might be easier to work on (not sure) if you first pulled the whole fender flare. That's really easy.
ParadigmDawg
Greg
Fort Worth TX
I started with a blunt awl and it was definitely cleaner and no damage. A little slow for me and I was fender chopping so I switched to drilling them out. Took like 3 seconds per rivet
stl jeep
St Louis
2024 JLU Rubicon X
Did you have issues with the rivets bulging when you drilled them out? I’m worried I won’t be able to reattach?
ParadigmDawg
Greg
Fort Worth TX
The rivets are ruined but if you don't go too big, they holes will be fine and you just pop in new rivets.
Reinen
Utah
Plastic rivets cannot be re-used. You must destroy them to remove them. They're cheap but you do need new rivets.
stl jeep
St Louis
2024 JLU Rubicon X
The concern is the damage done when removing the metal rivets. Making sure I can put in new rivets that will hold when reattaching.
