Rubicon factory rake
rubited19
Ted
Ohio
20 JL
What is the factory rake on a rubicon? I appears to be 3/4”. Can anyone confirm?
Biohazard
Nathan
Bristol, TN
2018 JLUR (sold May 2020); now own 2020 trd pro Tacoma
Sounds about right.
dsievert66
Don
Rockville, MD
2019 Jeep Wrangler JLU Rubicon
Technology and Analytics
"Newbe" jeep question: Whats the proper way to measure rake? ...putting a Level on rock rails or measuring the ground to center of outer wheel well fenders (Through center of wheel)?
I have yet to install a lift and I have an aftermarket steel bumper and winch and I'm only showing about 1/2" measuring to center of fenders on a 2019 JLUR.
Jteakus
Oil City Louisiana
2020 Ecodiesel Unlimited Rubicon
I had issue with measurements for level too. The rock rail and a 2' level gave me my best location. I set the level on the rail and jacked up the front bumper till the bubble was centered. Took a 3/4" spacer for mine and it looks great.
Whiskey 13
Northwest Florida
2020 JLUR White Rubicon, Warn 10000 Lb. Winch Syn. Rope, 35X12.5 KO2
I put a steel bumper and 12K winch on my JLUR, I also will not be going any bigger than 35" tires so I used Teraflex 1.5" spacer leveling kit on mine. 2" in front 1" in back and I am nice and level. Took care of the sag from added weight up front and it sits and handles great.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Rock rails, or even hardtop, would probably be the best measuring points for rake. The front fenders of the Rubicon are higher, so only a good measuring point for before and after lift measurements.
Jteakus
Oil City Louisiana
I looked at the hard top but it seemed to have a slight curve to it.
Talking spacers, is there a company that makes a 1” for the rear?
Dr. RGB
Ryan
Leesport, PA
2025 JL Willys 2-Door
Professor and Shrink
Seems about right since most leveling kits (without the rear spacers) measure about 3/4 inch.
Cuyose
Shawn
Piedmont, SD
2020 Jeep Wrangler Rubicon
Data Analyst
I have a 2020 rubi with steel bumper and warn evo 10K winch with adapter plate and notice no rake as the eye can see. All stock suspension.
Melny67
Melvin
Staten island
Jeep jlu
I have a sport s with a badland apex winch and a arcus bumper. Going to install rubi shocks and springs. The sport s shocks and springs have a even lower front rake stance then the rubicon. What spacer should i use. I dont want to install it twice and measure to check what kind of spacers i need. I am thinking a 3/4 is not gonna be enough maybe a 1". Also i rather not get a full front to back leveling kit. i want to install front leveling spacers.
tonygiotta
Tony
Turlock, CA
'18 Firecracker Red JLUR
Fire Captain
I always assumed the Rucibon rear fenders were higher too, no? I’ve always used the seam between the upper and lower pieces of the fender flares (centered over the axles) as my measuring points for adjusting my coilovers. Seems to look level to me when I set them at the same height front and back. Still undecided on how much rake I want to run though. My thought was to load up all my camping gear, and then set it level. Figure that will give me a little rake when I’m empty.
Headbarcode
LI, New York
I know the rear fenders are a different size and shape between the Rubicons and others, but not sure about height.
A bit of rake when unloaded is better than sagging under load.
