JLUR Factory Rake and Teraflex Spacers
  1. KevinLC
    KevinLC Active Member
    First Name:
    Kevin
    Vehicle(s):
    Jul 23, 2018
    Lubbock, TX
    Liked:
    59
    Always afraid to start a new thread...but I CANNOT get clarification on this. My stock JLUR with 315s appears to have a very slight rear sag. I have looked at dozens of pics, and JLURs appear to me to be perfectly level or a bit of sag. Here lies the rub: I have a Teraflex 1.5 kit sitting at my house that I plan to install today. This kit has a 2" front spacer and 1.5 rear to "level the factory rake of the JL." I am seriously questioning their judgment and am afraid I am about to add more sag.
    Because of the above dilemma and because of this forum, I ordered a Teraflex 2-door kit with includes a 1-inch front spacer and 1.5 rear "to correct the factory rear sag of the 2-door JL. I also ordered a .5 levelling kit that can be added front or rear as I see fit. This plethora of spacers is waiting at home.
    My plan was to either do 1.5 all around, or do 1.5 front and 2 rear using a combination of spacers. Does anyone have any experience with this or guidance before I install a complete kit...hate it...and then install a completely different one? I am doing this myself in my garage, so it isn't exactly easy to just throw another spacer in or take on out if I don't like the setup.
    Do JLURs sag?!?!
    Thanks in advance...
  2. Fonzilla85
    Fonzilla85 Well-Known Member
    First Name:
    Alfonso
    Vehicle(s):
    2018 Jeep Wrangler JL Rubicon Unlimited
    Dec 7, 2018
    Ventura County, CA
    217
    Liked:
    246
    Occupation:
    Professional Gunslinger
    I didn’t notice any sag on my Jeep. I utilized a 1/2 inch spacer in the front when I installed my lift, to compensate for the winch and bumper. Do you have any heavy gear or equipment that may be causing the sag?
    KevinLC likes this.
  3. OP
    KevinLC
    First Name:
    Kevin
    Vehicle(s):
    Jul 23, 2018
    Lubbock, TX
    Liked:
    59
    Nothing. I have hardtop (assume that's a bit heavier) and a 315 spare mounted on the back...but that's it.
  4. Fonzilla85
    First Name:
    Alfonso
    Vehicle(s):
    Dec 7, 2018
    Ventura County, CA
    217
    Liked:
    246
    Occupation:
    I don’t think the tire is heavy enough to weigh the back down, but I’ve been wrong before. Hopefully the lift your planning to install will help with this issue.
    KevinLC likes this.
  5. mysto
    mysto Well-Known Member
    First Name:
    Michael
    Vehicle(s):
    Sting Grey 2 door JL Rubicon
    Nov 4, 2019
    Utah
    Liked:
    34
    The rear fender isn't as high as the front, which makes it LOOK like it's sagging. I created a level parking spot using boards and a laser level, then checked the level of the rails / running boards, and it's dead straight there is no rake. JLR stock. Clearance of the fenders is different if you measure that.
    KevinLC likes this.
  6. Cypher
    Cypher Well-Known Member
    First Name:
    J
    Vehicle(s):
    2020 Jeep Wrangler Unlimited Rubicon
    Feb 8, 2018
    AZ
    1,399
    Liked:
    1,076
    Occupation:
    Cybersecurity Leader
    Garage Profiles:
    My 2020 JLUR passenger rear side is about 1/2 in lower than the drivers side. The front is a bit lower than the rear with all of skids, bumper and winch etc.
    It has had the lean on the passenger side rear since I bought it. My 2019 did not do the same thing. I am sure it's from the gas tank, sometimes it really bothers me, others I don't care. I plan to do a small lift anyways so I never worried about it too much.
    KevinLC likes this.
  7. OP
    KevinLC
    First Name:
    Kevin
    Vehicle(s):
    Jul 23, 2018
    Lubbock, TX
    Liked:
    59
    After hours of staring at my Jeep today, and using two floor jacks to simulate my lift options...I think you are exactly right. The JLUR is perfectly level, and the appearance of sag is related to the fenders. I'm going to install 1.5 all the way around tomorrow instead of the Teraflex-recommended 2 in front, 1.5 rear. Pics to follow.
    mysto likes this.
  8. Buckster
    Buckster Well-Known Member
    First Name:
    Vehicle(s):
    '19 billet silver JLUR, '16 Grand Cherokee Overland, '12 BMW 328i cab
    Jun 18, 2019
    Charlotte-ish
    264
    Liked:
    772
    Occupation:
    Power Generation
    Garage Profiles:
    #8 Jan 10, 2020
    Pics would help.
    I was in the opposite camp. Stock JLUR with soft top. To my eye, the rear always looked higher than the front. Using a level on the rock rails confirmed a definite forward rake. Installed 3/4" spacers up front and much happier with the stance now.
    For me, it's not about the wheel wells looking equal but the relationship of the rail to the ground.
    Bryce and mysto like this.
  9. OP
    KevinLC
    First Name:
    Kevin
    Vehicle(s):
    Jul 23, 2018
    Lubbock, TX
    Liked:
    59
    I'm going to try that today...level on the rock rail. I have about decided on 1.5 all around after spending hours yesterday with two floor jacks adding and removing lift and analyzing the rake. Something will be installed tonight.
  10. Wch_chip
    Wch_chip Member
    First Name:
    Danny
    Vehicle(s):
    2019 JLUR 2020 JT LE
    Aug 4, 2019
    Augusta Ga
    Liked:
    Here is the same lift kit on the same size tires. Hope this helps.
    EDIT. My driveway is not level and slants to the front of the vehicle in this picture.
  11. OP
    KevinLC
    First Name:
    Kevin
    Vehicle(s):
    Jul 23, 2018
    Lubbock, TX
    Liked:
    59
    That does help...and to be clear, when you say "slants to the front" you mean the front is downhill from the back, correct? Otherwise, it looks like a fairly significant rake. *Edit: That is my favorite JL color...hands down.
  12. Wch_chip
    Wch_chip Member
    First Name:
    Danny
    Vehicle(s):
    Aug 4, 2019
    Augusta Ga
    Liked:
    The front is downhill from the back.
  13. Bryce
    Bryce Well-Known Member
    First Name:
    Bryce
    Vehicle(s):
    2019 JLUR
    Jun 2, 2019
    Acworth, GA
    399
    Liked:
    769
    Garage Profiles:
    #13 Jan 10, 2020
    Exactly the way mine is. JLUR, soft top, steel bumpers and winch. Mine is ~3/4 lower in front measured off the rails.
    KevinLC likes this.
  14. OP
    KevinLC
    First Name:
    Kevin
    Vehicle(s):
    Jul 23, 2018
    Lubbock, TX
    Liked:
    59
    With the top off...my rake is pronounced, and I like it. Top on...questionable. These aren't the best pics for the analysis, but they're what I have.20190605_134643.jpg 20190603_130430.jpg
  15. OP
    KevinLC
    First Name:
    Kevin
    Vehicle(s):
    Jul 23, 2018
    Lubbock, TX
    Liked:
    59
    Done. Teraflex 1.5 front and rear.IMG_20200113_175356.jpg IMG_20200113_175350.jpg IMG_20200113_175408.jpg
    DerekPB and rajinator3000 like this.
Loading...
Share This Page
