Roll Bar Trim Replacement
JeepWhealen
Josh
Bristow VA
Previous: 2015 JKU Sport S Current: 2023 Willys XR
I recently installed the Dominion Off-road roll bar Hi Lift Mount in my JL. Part of the instructions said to trim the plastic molding slightly to be able to reinstall it. I fabricated the first one perfect, however I messed the second one up. Anyone know where on the Mopar site to replace this plastic molding trim piece?
Gregj
Greg
West Texas
Part number is usually molded in on the back side.
Gregj
6th Floor Mule
Keith
Woodstock, GA
2018 JLU Sahara 6MT
6ER96TX7AB and 6ER97TX7AB are the 2 small covers covering the soft top attachment point bolt holes. Just bought a pair of them myself a month or so ago. Not sure which covers you’re referencing though.
JeepWhealen
JeepWhealen
Josh
Bristow VA
This is helpful, thanks! That seems to be the piece I was looking for. It is a piece of black molding covering two bolt holes
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
Hi Josh,
There's quite a few different pieces so I attached a parts diagram of them with part numbers.
Please let me know if you have any questions.
Thanks,
-Benny
6th Floor Mule
Keith
Woodstock, GA
2018 JLU Sahara 6MT
These little buggers . . . if you’re going to mess up a cut, may as well be on the easily replaceable cheap part!
Jeep Wrangler JL Roll Bar Trim Replacement B90AF5F7-B290-472C-ADA0-D77634C13113
JeepWhealen
JeepWhealen
Josh
Bristow VA
Yes EXACTLY!! Figured it was a cheap replacement so I could do it better this time around. Thanks!
JeepWhealen
JeepWhealen
Josh
Bristow VA
Hi Josh,
Thanks,
-Benny
Great thank you! I’m about to order a replacement, thanks!
