The Great Grape Ape
- Mar 30, 2017
- Canadian Rockies
- 2015 JKU AspenX 5spd , 2015 JK Sport 6spd
@wired.... Ace Sliders use body mount bolts (2 on each side)
3 on the Unlimited.
Yep, good advice, definitely do one side at a time. (axle stands/jacks are even handier, but put a towel on them to keep from scratching).Note: Do not take out all 4 body mount bolts and then do the slider install. Do one side of the vehicle at a time. Helps to have a second set of hands to hold up slider during install. Tighten up body bolts properly!!!
If doing solo you can use your knee to help prop up the rail during install when facing them, but I found the foam works best, allowing you to maneuver.
Also, loosely install bolts then tighten back and forth to ensure one side isn’t cranked while the other loose.
