OversandJL
- Nov 22, 2017
- Massachusetts
- 2018 JLUR, 2017 JKU Sahara, 2014 JKU Sport S, 2007 JKU Sport, 1997 TJ,
This is correct, but rock crawling would definitely be the most common scenario for max flex/droop to occur tearing the driveshaft boot.It doesn't really matter if you rock crawl or not, it's a function of shock extended length. If you have shocks that allow sufficient droop you'll tear up the stock shaft whether you're on rocks or not.
