Rear license plate relocation options...?
Crusifix
West Virginia
2019 JLU Rubicon 2.0T Hurricane
I'm probably going to end up fabricating something, but I am looking for an option that will let me keep the plate mounted anywhere but on the spare or in the middle of the swing gate at all. I am switching out rear bumpers, and I am just hoping to see some different options people have came up with... that do not include center mounting it. I've been searching for the last two days, and it is getting to crunch time. There just aren't any great options from the big vendors, so I am hoping one of the smaller guys has came up with something.
Thanks,
-Jeff
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
The JK position is the only other spot I've seen, that doesn't interfere with departure angle. If memory serves, lod is the popular one. It just ends up overhanging the side of the body, which is the chief complaint.
Crusifix
Crusifix
West Virginia
I was thinking that you needed their bumper for it to work? If not, then that may be my go to. Thanks!
Headbarcode
LI, New York
I've yet to look into that specific part, because I'm fine with the spare location. Just going by mentions around here, it sounds like a universal part.
ConqSoft
Keith
Wake Forest, NC
2024 Gladiator Mojave
Systems Analyst
Yeah the LOD one is probably your beat bet. Not many options out there. It’s made to work with LOD bumpers but you could probably fabricate something up to work with others if you’re handy.
JLRyder
2019 JLUS
Same issue here, couldn’t find anything I was happy with. Ultimately settled with the center of the spare because the bumper I wanted didn’t have a license plate option. I ended up with a mix of the rugged ridge 3rd brake light relocation (came with the Spartacus HD tire carrier) the rough country plate relocation kit, and the Quadratec license plate light (the light that came with the rough country kit was way too small) I didn’t want to cut or splice into the factory wiring so I used the Quadratec light kit because it has a factory connection, I then cut it, ran a two conductor jacketed wire between the factory connector at the bumper, up through into the cab, factory swing door, to the license plate. Not for everyone, but works for me. First post, hope this helps!
Jeep Wrangler JL Rear license plate relocation options...? 594747A0-A349-484C-A42B-A2F2BFD0A11D
Jeep Wrangler JL Rear license plate relocation options...? 35238B39-8CEA-49E4-BEC1-2466A00AF5C3
Jeep Wrangler JL Rear license plate relocation options...? AEEF7084-749C-47E3-828E-347EB1A56CCA
ConqSoft
Keith
Wake Forest, NC
Systems Analyst
Yeah I ended up doing the same with an Artec myself, and rigged up a LED bolt light with a quick disconnect. Ran wiring through the tailgate, using the Quadratec kit to plug straight into the factory wiring harness. I, too, avoid tapping into any factory wiring at all costs.
My Smittybilt rear bumper actually came with a license plate relocation kit to the spare tire, complete with a light, but I wanted the higher quality Artec one.
Jeep Wrangler JL Rear license plate relocation options...? 5DAA05AE-4A3B-4195-A500-32035C3F2CBD
Jeep Wrangler JL Rear license plate relocation options...? 66361730-34D9-4087-BE59-B64787923335
Jeep Wrangler JL Rear license plate relocation options...? 027DC35E-73AC-4E24-9B0D-2D1E54B87B26
Jeep Wrangler JL Rear license plate relocation options...? BDFF4095-AAFE-4220-8E72-8175128E3DCA
Boutch76
Yannick
Vancouver
2018 Jeep Wrangler Sport JL 2D Manual
SadRobot
Los Angeles
2025 Prius LE
jhackathorne
Denver
'21 JLUR
How did you wire the light in?
Not likely for you to get a response from him since he hasn't been seen for close to a year. I will be doing nearly the same mod as he had, but am wiring it the same way Rough Country says to wire their light. Their directions have you wiring it into the parking lights and starts on page 3. While I have not done it yet, I can't imagine there will be any issues. I am waiting on new bumper to come in and then will get it all wired up. Good luck.
https://s3.amazonaws.com/roughcountry/install/921105340.pdf
XX4XEXX
JD
Ca
2021 Rubicon
Mechanical Engineer
@TMR makes 2 types of plates to relo that are mountable anywhere.
Thanks,
-Jeff
jhackathorne
Denver
'21 JLUR
Damn, nice necro and way to prove @jhackathorne wrong! I always knew you had it in you :like:
What are you even talking about proving me wrong? The RC instructions do not have you splicing into the wires they demonstrate. Perhaps you should have looked at the instructions to see how RC is running it.
